Question about Air Tools & Compressors
10 gal kobalt compressor makes a clicking sound and wont pump up my tires
    Top Expert:
  • 45,531 Answers
Look for blocked non-return valve from compressor line to tank
check that each poppet valve for each cylinder is operational as the small springs break and do not allow the air to pump up
Posted on Apr 13, 2015
Oil capacity of kobalt 80 gal air compressor
You could do a little searching on the web, and answer your own question. You can buy a manual for $4.95 at:
http://www.needanownersmanual.com/product_info.php?cPath=21_30&products_id=549&osCsid=tks6fj36b6skq8h7m155hh8kb1
But worse, you don't even need an answer to this question. Simply add oil until level is about half-way up the sight glass. And don't overfill. How simple is that?
Feb 08, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Screwed wingnut the wrong direction when trying to drain 60 gal. Kobalt compressor....can it be put back on?
call lowes there might b a service to get it fixed sound like u broke something to me get help
Apr 21, 2012 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
HOW TO WIRE A KOBALT 60 GAL VERTICAL 208-240 TO BREAKER PANEL
i have a KOBALT 60 GAL VERTICAL 208-240 wired up like it should will not start or nothing
Feb 09, 2010 | Air Tools & Compressors
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
On my kobalt digital air compressor i have 150
This was a poor design for kobalt with digital readouts.. The compressor waqs made by several comanies including campbell hausfield and porter cable, But some were imported.
There under the controls is a switch that cuts out the motor, It looks like an oil pressure switch on older cars. There is also a manifold tree that holds the guages and the regulator. There will also be a circuit board that holds the electronics for the regulator control.
Remember you have to set a value to bring up the pressure and the board senses the tank pressure and "Bleeds" off via a solenoid to hold the pressure. The ticking sound you hear is the solenoid, ITs not repair/replacable.. its part of the controls.
If the unit is under warranty you might eant to ask lowes who is their off site repair center, or ask is it available to be exchanged.
Personally, and professionally.. this model is oiless, so it has a shorter life as to being reliable compared to oil lubrication. For the extra bucks you will come out with a more reliable and easier to service model.
Nov 18, 2009 | Air Tools & Compressors
Kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Jul 23, 2009 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
I have a Kobalt 26 gal compressor that takes 10 min. to build 80 psi in the tank and will not go above that.
when is last time you drain the tank might be water in there it should be done daily or when ever you use it. And check the regulator make sure it where should be i keep mine all the way down.
Jun 13, 2009 | Air Tools & Compressors
Air Compressor
Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
Apr 01, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Air Tools & Compressors Logo
158 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
