Question about Home
Plumbing problem ..... we have no water pressure in the shower area ... The sink and toilet is fine for pressure , the wash machine on the other side of the wall is fine for pressure , when we take the valves out there is full pressure .. When we put them back in there is no pressure ... The shower set is new ....
    Top Expert:
  • Home Master
  • 51,280 Answers
Remove the shower head or hose at the wall
some manufacturers have a small restriction in there that becomes blocked from any thing in the line
I have found that the shower works well with out it any way
Posted on Apr 13, 2015
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 | RVs
Tip
How to check for a leak in the water pipe of your building.
First you must ask your self, well water or city water? Well Water , first turn all plumbing off, no sinks showers dish washers running ext. Second sit and wait by the pressure tank, watch the gage if it drops and the well pump kicks on you have a leak.When doing this it make take a while of sitting their and watching depending on how small the leak is.
City Water First thing turn all plumbing off, no sinks showers dish washers running ext. second watch the water meter, if it moves then u have a leak, the smaller the leak the less it will move and the longer you will have to sit and watch.
Toilets have fill valves that fill the tank up after each flush, and a flapper that allows the water to drain. these parts go bad over time and should be checked once a year you insure you aren't wasting water and money.
on Mar 28, 2010 | Plumbing
Does shower / tub drain into black water tank
Would depend on the plumbing, but usually yes. Only toilet water doesn't.
If you have access to the black water tank, you can put dye in the shower, and then test it.
Jul 07, 2016 | Home
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
Help me locate a leak in the bathroom
need to check connections going to shower. turn on water and see if runs down lines. also try to reach up to the sink connections a do the same. they tend to come loose. should be able to hand tighten. also check behind toilet at connection.
Oct 08, 2014 | Jayco 2011 Greyhawk 31 SS
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
I recentlly had a Danze model # D11200BT installed in my tub shower. The problem is every time you turn the water off there is a banging sound that comes out of the valve it self. The sa me thing happens...
You have what is called water hammer effect going on the water pressure is to high this can cause problems with all you plumbing fixtures. You need to have a water hammer arestor install or put a main line pressure reducing valve in.
May 29, 2011 | Danze Plumbing
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Nov 21, 2008 | Saniflo Sanibest Grinder Pump Only 013
Home Logo
295 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
