Question about Toys
I have john deere gator 620i clutch will not engage
  • 19 Answers
SOURCE: Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 670 Answers
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Jul 27, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do I fix john deere 620I gator steering assembly
then why do you not look for the bent rod and unbend it or replace it .
May 26, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do i adjust the throttle position switches on a john deere gator 620i
YOU DONT! Factory specs are need to test and set it!
First off what is the problem you are having????
All the TPS does is switch from one timing curve to the other on the cdi, and is also connected to the fuel management computer to tell it when to increase fuel delivery.
If you are having running problems start with old fuel, fuel pump pressure, and last if you have modified the airbox or exhaust in any way it will run like crap! On fuel injection you have to get a tunable fuel management computer when increasing air-flow or exhaust flow. The fuel injection is set from the factory based on the OEM parameters.
How many hours/ miles on your unit?
Have the valves been adjusted if it has over 200 hours of use?
are there any codes being flashed on display when key is turned to on position but not running?
Aug 29, 2014 | John Deere 2008 Gator XUV 4x4 620i
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
Jun 30, 2012 | John Toys
How do I open hood of john deere gator 620I 2008
the hood doesn't open on this toy but the front grill does flip down
May 20, 2012 | Peg Perego John Deere Gator HPX
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
Toys Logo
305 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
