Question about Sharp LC-32D6U 32 in. LCD Television
How do I fix the color?
My tv was working fine using one of those small comcast boxes. I gave it my neighbor and we connected it to a DVR player using the red, green and yellow cables, and the color is now off even though I have done everything, including gone back to factory settings. If the people are too green, and I adjust, then the grass and flowers turn brown. Could it be the difference in the connections?
  • 208 Answers
SOURCE: Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Posted on Feb 05, 2008
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
SOURCE: My 2-day old Sharp lc-52sb57u
hit menu, go to setup, select input skip, then just go down the list and make sure they're all set to "No"
Posted on Dec 11, 2009
circuitworld
  • 335 Answers
SOURCE: I have a 42 in. Sharp Aquos HDTV - accidently
Try a different AC cord first the one you have may a resistance problem. Also try plugging it into a different wall outlet. If still the same problem, somehow your convergence circuit has a fault.
But see if another ac cord works for you first...
get back to me on this when you have time.....
circuitworld@comcast.net
Posted on Dec 29, 2009
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
TV Guide on Line for viewing and recording was there and poof
Good Luck!
Mar 25, 2009 | Panasonic DMR-EH50 DVD Recorder
On screen guide
I am in Atlanta and have aPanasonic DVR that was working fine and sometime during the past monthor so we lost the channel listings. I've tried many resets as well withnegative results.
I called Comcast tonight. The agent helping metook a long time to research the issue and gave me this answer (whichsounds reasonable). By the way, this is for the Atlanta area and maynot be applicable to other areas of the country.
Due to delaysin the conversion to broadcast digital and the fact that Comcast isexperiencing bandwidth issues, they have digitized the "channellisting" signal. By mid-June Comcast's signal will be all digital andyou won't be able to watch a TV connected directly to Comcast cable -regardless of whether it has digital or analog tuner (or both). This iscontrary to what I'd heard before.
After mid-June, you'll eitherneed to use a cable box OR what she called a "Digital TransmitterAdapter" (let's call it a DTA). Prior to being converted to "full"digital, you'll get notification from Comcast. She said I'd be able toget 2 DTAs at no charge (I currently have one Comcast HD DVR box).Additional DTAs would be $1.99 a month. DTAs will only provide accessto the "basic" cable channels, but the good news is that the PanasonicDVR should be able to obtain its channel lineup through this DTA box.
Good Luck!
Mar 21, 2009 | Panasonic DMR-EH50 DVD Recorder
Comcast DVR 3 Remote doesn't work with TV
You may have to use a separate remote control for your TV.
Jun 05, 2017 | Emerson Televison & Video
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Sharp LC-32D6U 32 in. LCD Television Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
