MAN TGA440 FAULT CODE3076.09 AND read code error / Interlock active and woulddnot start please help
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check presour switch
Posted on Apr 12, 2015
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
Hay Dear my windows 7uitimate with anytime up gread copy is over 100% genuin and use my personal laptop acer (aspire 4741) . but my sons miss use and some device dont work so my windows reinstol my copy...
Ok when problems with activation Microsoft products you can call Microsoft in your country. They ask your code and you will get a working code. If the error is an windows installation fault you first need to reinstall your windows.
Feb 13, 2011 | Acer Computers & Internet
I have a Canon IR C3220, and i started off with the yellow drum error code, which i just replaced, and now I'm getting error code E000020-0125. Can you please help me?
It is possible the front door plastic door interlock for the SALT sensor shutter is broken or not in place, (see picture below). If the shutter is not actuated by the interlock, the SALT sensor will error out when trying to perform ATR measurement resulting in an E020. Sub codes will be related to yellow ATR measurementsince it is the first color laid down on the ITB for ATR measurement.
Sep 07, 2010 | Canon imageRUNNER C3200 Copier
Sharp microwave carousel R330J 1100 watt. When the heating cycle is started the microwave light flickers on and off and there is a clicking sound. Initially high voltage fuse blown. replaced fuse and...
Hi and welcome to FixYa. I am Kelly.
1st the model number appears to be incomplete. Not an issue at this point but will be if you need parts.
You most likely have an interlock problem with one of the 2 door switches or the door interlock mechanism is broken.
There are 3 safety interlock micro switches activated by the door. One for the light, one for the Magnetron and one for the control panel power. If the problem persists with the Magnetron disconnected. The Magnetron safety interlock micro switch is supposed to blow the fuse if the unit is energized with the door open. Check continuity of your door interlocks. Pat particular attention to the NC (normally closed), C (Common) and NO (Normally Open) contacts.
NC should read to C and when the switch is activated read open at which time the NO contact will read to C.
I really suspect a bad microswitch.
Thanks for choosing FixYa.
Kelly
Aug 21, 2010 | Vacuums
Fault code dL and F. please help me. the machine show this when is plug in but not on a program, can not start it
The FdL fault code usually refers to problem with the door interlock. Normally when the machine is on a program the door locks to prevent inadvertant opening.
This fault code indicates the interlock is not working and it will not start.
Check the lock for any obvious signs of debris or damage but if none it may need a replacement.
Jan 23, 2010 | Whirlpool AWM8000 Front Load Washer
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
