Question about Garden
Why does my weed eater smoke? - Garden
  • 1,169 Answers
Since this posted under lawn trimmers I am assuming you are using a 2 cycle version. Some smoking can be normal as the fuel contains oil. IF you are worry about the smoke try a fuel oil that is smokeless.
Posted on Apr 12, 2015
    New Friend:
It is my understanding that many weed smokers eat. Apparently it even has a name, munchies.
Try this instead for more info
http://nb.urbandictionary.com/define.php?term=Munchies Munchies
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to know the gas ratio to use in a homelite(trimlitr) weed eater.
50:1 if that is too rich the weed eater will give off white smoke then use 30:1
Jun 18, 2011 | Homelite Mighty Lite Lawn Trimmer
My leaf eater starts to smoke. Where, or is there a place to oil the moter?
the electric motor should not need oiling sounds like you are running on a lightweight ext cord and under powering motor try hooking up to a plug directly into outlet see if problem persist
Nov 07, 2010 | RTO Weed Eater Electric Barracuda 2595...
What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Aug 09, 2009 | Garden
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
