I own a Harmon Kardon CD2 recorder. Is this a problem with the remote or the recorder itself?
I get an audible click at the very beginning when I am recording individual tracks from various sources and sometimes when I am separating the tracks from an LP or CD. Very rarely do I get silence at the beginning of a track. Remote is always used as opposed to using controls on the CD 2 itself.
SOURCE: Recorder will not complete analog recording
I've discovered that it sometimes may be the disc(s) used. If I use cheap quality blank discs, I have had this problem. I use the manual record extensively with high quality discs recording from vinyl with no more issues...
Posted on Dec 05, 2007
SOURCE: Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: how do get multiple tracks when djing
press the next botton on the recorder every time u switch songs djin".
Posted on May 01, 2009
SOURCE: When I record a vinyl album on a CD it all winds up on one track.
Pause each song for every recording to separate the tracks.
Posted on May 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: it wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Posted on Nov 20, 2009
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
MX-450 universal remote code for AVR-354
Harm an / Kardon 0 0 8 1 ,0 0 3 8
Sep 14, 2009 | Televison & Video
Harmon Kardon receiver not compatable connection to subwoofer.
Most subwoofers with RCA type connections are powered subs. They are commonly sold in most hi-fi stores.
Unless your subwoofer has a separate mains lead it will be the wrong type I think.
Dec 07, 2017 | Harman Kardon HKSUB 12 Subwoofer
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Harmon/ Kardon ST-8
Harmon kardon.com and check product support or check the website where you got them from, If they still cary them you may be able to find a manual as a pdf or something. Good luck. Bonne chance!
Feb 26, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Harmon Speaker distortion
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
Dec 02, 2006 | Harman Kardon Harmon Kardon SoundStick II...
 Grubhead
Grubhead
