Question about Dryers
Dryer thinks the door is open
Wont run or change setting while child lock is engaged. when I unlock it, it will run but never heats up.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Sounds to me the child lock is working normal. What model dryer? Electric or gas
Posted on Apr 17, 2015
  • 1 more comment
  • johnna
    johnna Apr 17, 2015
    Samsung gas dryer
  • johnna
    johnna Apr 17, 2015
    While child lock is engaged, I get a DO code
  • Luke Thomas Apr 21, 2015
    If it thinks the door is open only in child lock mode, sounds to me like a bad control.
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
SOURCE: whirlpool dryer problem
dryer works but does not heat up
Posted on Aug 11, 2008
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
  • 221 Answers
SOURCE: When drying clothes in my gas dryer, you can smell
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Posted on Jan 17, 2010
2000 Ford Explorer back door driver side door WILL NOT unlock
For this type of problem I recommend YouTube. Always a wealth of information on rear gates door locks etc.
Google > YouTube 2000 Ford Explorer door locks
Oct 08, 2017 | Ford Cars & Trucks
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
Oct 07, 2016 | Cars & Trucks
Free holden manuals
child locks are on the back doors only and are underneath the door at the trim edge around seat height. If you cannot open the door from the inside but can from the outside then it has child locks.
Aug 13, 2014 | Cars & Trucks
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
How do I unlock child lock on a Samsung electric dryer?
In the owners manual there is directions on how to unlock it, sometimes as simple as just holding down the child lock button for a period of time
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | Samsung Dryers
My back doors wont open, the child safety locks wont unlock my back doors
Your post is somewhat confusing, BUT with child locks engaged, you can only open the door from the outside, when unlocked.
Jul 10, 2011 | 1999 Ford Explorer
My aunt claims that when her sister accidently set the car alarm lock when she was napping in the car that she was locked in it. She says she could not get out. Does Chevy actually make the 2009 Equinox so...
the only thing i could think of would be the child safety feature but that is usually only for the rear doors. i think she just panicked because the front doors are set up so that if you pull the door lever the lock pops up.
Feb 22, 2010 | 2005 Chevrolet Equinox
When i push child lock button on my C220, doors automaticly locks and i can not open back doors from inside, but in 6-7 seconds I can open back doors from inside. Why child lock functioning 6-7 seconds?
If you want to keep the child-locks engaged, and doors unopenable from inside, you must set the lever by hand inside the rear door jam of each door. It should be marked, locked/unlocked or on/off. Are there other issues I am not addressing? I hope this was helpful.
Online tonight, TaterTodd
Jan 29, 2009 | Mercedes-Benz C-Class Cars & Trucks
Dryers Logo
127 people viewed this question
Top Dryers Experts
