Question about Garden
Mower runs awhile and just quits like the gas is turned off. Changed gas line, filter, drained gas tank and changed air filter. Help
  • 1,169 Answers
Next time it quits check for spark at the spark plug. You may have a failing ignition coil electronics which manufacture into the coil pack.
Posted on Apr 12, 2015
22 hp in husqvarna mower, will crank and run 2 or 3 seconds and quit, have changed fuel filter and checked for water in gas
If it starts and runs, even for 2 seconds, it's more likely to be a fuel problem than an electrical one...I'd first suspect the carburetor float/valve being gummed up, especially if you've left it sit for the winter with gas in it...if that isn't it, then remove the gas tank and check the tank and lines to the carb for obstructions...
Jan 01, 2015 | Husqvarna Garden
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My 1998 contour svt has been sitting for two years, trying to start car, it wont..is the gas bad in the tank
If it's been sitting for that long, yes the gas goes bad. Drain the tank, fuel lines and even the spark plugs becuase the old gas will foul them too.
Check air filter for free air flow and possible critters living in the intake... two years is quite a while for a car to sit... Also after it's running have your oil and filter changed as well.
Nov 25, 2009 | 1998 Ford Contour
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Runs for awhile then will quit
Have the fuel lines or engine shielding been modified at all? Has the fuel filter been changed?
If all of that is OK, remove the fuel line from the tank at the fuel pump, remove the fuel fill cap, gently blow air back through the fuel line so you can here bubbles in the tank. The "tank pre-filter" could be plugged.
Let me know.
Regards,
May 14, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
