Question about Optics
How to dismantle and lighten trigger tension - Optics
  • 2,192 Answers
Moved my tension button and not sure what to set it on, sewing polycotton curtains
uually your tension should be set between 4and 5 this is a good tension for most fabric
Dec 27, 2017 | Sewing Machines
Tension settings to sew denim on my brother LS 2125
If you are using standard weight thread, just set the tension at the midway point. The tension may start out too tight, so you'll just need to lighten the upper tension until it's where you want it.
If you are using heavier thread, then you'll probably need to loosen the bobbin tension as well as the top tension. (Frankly, I would try to avoid that prospect as you'll need to change the bobbin tension back to where it was when you start a different project on lighter weight fabric). Be sure you use a denim needle, or even top stitch needle.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Nov 09, 2016 | Brother Sewing Machines
My electric GPW 1600 doesn't stop running when I let off the trigger?
Mostly they don't.
In order to ensure there is no delay in building up pressure for the next spray requirement and to lighten and cheapen the design, the motor is kept running to keep maximum pressure in the line and surplus pressure is recirculated through the pump after being ejected through the unloader or regulator valve.
Jul 16, 2016 | Electric Garden
How do I lighten trigger pull on a 22 deringer
You need to to tone the sear to be smoother but be careful if to much it won't hold well and it will go off without pulling trigger it doesn't take much if you try this stone lightly and try repeat till you get it where you want it
Jan 25, 2015 | Cars & Trucks
How to lighten trigger pull on 303 Parker Hale rifle?
You'll have to change triggers. That one is made for 4#.
Jun 14, 2014 | Optics
Wont restart
high pressure cut out switch faulty. dismantle unit dismantle and clean or adjust r replce micro switch ( on pump head )
Apr 19, 2014 | Task Force 2000 PSI Electric Pressure...
I have a 28 deg Bostich framing nail gun that is leaking air around the trigger. Not sure which seal, but need help in dismantling it to check which o-ring is broken.
you need a trigger assembly it sounds like/ to remove you will find 3 roll pins, unplug the air supply and remove all the roll pins in the trigger/switch and then the trigger valve ssembly is easily removed BUT follow closely, after removing the roll pins remove the trigger and then holding a rag under the trigger assembly pull back on the collar to release the bit. clean with chemicals and try ing to find that special commodity.
Dave Ford
Nov 01, 2010 | Stanley Tools & Hardware - Others
Trigger fell out
I would advise you to send the product back to the
manufacture, either for repair or refund.
Jul 19, 2010 | Toys
High pressure issue
THERE SHOULD BE A PRESSURE REGULATOR ON THE PUMP YOU CAN ADJUST FOR MORE PRESSURE THIS COULD BE THE PROBLEM. ONCE YOU PRIME THE UNIT THE REGULATOR SETS ITSELF AND WHEN YOU PULL THE TRIGGER AGAIN THE SEAT AND SPRING MAY BE STAYING OPEN AND NOT LETTING THE UNIT BUILD PRESSURE
Aug 19, 2009 | Karcher 2500 PSI Pressure Washer
Optics Logo
103 people viewed this question
Top Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
