Question about Curtis Sno-Pro Home Pro 3000 Snow Plow
The plow went up. and will go left and right, but not back down.
Plow moves right and left but only lifts4 to 6 inches
Also you may have to reset chain. set with plow piston all the way down and set with little looseness for plow movement downhill.
Feb 08, 2017 | Cars & Trucks
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
My fisher minuteman 2 plow will go up and left and right but will not go down
Most of those systems don't have a driven retraction on the piston. It is gravity feed back. There is a valve that is sticking or out of adjustment. http://library.fisherplows.com/?cat=38
Jan 24, 2015 | Cars & Trucks
I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Fisher plow lock up when training right or left.
Have a 2004 hmm and plow went up and down but jerked left to right but did not turn , found it to be wire harness going thru fire wall , sheet metal wore thru wires shorting them out , pulled harness thru and shrink rapped and hooked back up been working fine.
Nov 14, 2014 | Cars & Trucks
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Plow went to right wont go up or left
plow?...your question is confusing
Jan 18, 2011 | Ford Bronco Cars & Trucks
Meyers snow plow doesent move left to right
i am thinking the celanoids went bad or a bad ground
Feb 28, 2009 | RTO Michicraft L-13 Canoe By Meyers
Curtis Sno-Pro Home Pro 3000 Snow Plow Logo
172 people viewed this question
Top Curtis Garden Experts
Dennis Key
Dennis Key
john h
Are you a Curtis Garden Expert? Answer questions, earn points and help others
