Question about David White 44 8834 1 22x Level Transit Package
How do I Calibrate a David White Instrument TR-300 Transit. does not stay level when rotated
2 Suggested Answers
SOURCE: How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Posted on Aug 03, 2010
How to fix crooked cross hairs on David White transit level
don't believe that is a consumer fix . has to be sent in to them
Apr 27, 2015 | David White 44 8834 1 22x Level Transit...
How to change battery in remote for a 1997 BMW 528i, when trying to change the battery and tried to see if it worked nothing happened
You have to take the old remote key back to both Mercedes or BMW to change the battery. Little profit motive there!
Mar 08, 2014 | David White 44-8871 LT8-300P Universal...
Cross hairs stick, tap instrument it corrects it
Put it on its side and bang it on a counter...not too hard now
Nov 11, 2013 | David White 44 8834 1 22x Level Transit...
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
How to remove dash panel to replace climate control panel
  1. Remove the instrument panel accessory trim plate around the control panel by prying gently and then pulling it straight out.
  2. Remove the control panel mounting screws.
  3. Pull the control panel straight out from the instrument panel.
  4. Disconnect the electrical connectors.
  5. Installation is the reverse order of removal.
  6. After installation, the actuators must be calibrated. For additional information, refer to the following section, -Actuator Calibration.-
  8. Fig. Remove the screw and pull the control panel straight out of the instrument panel.
To calibrate the system:
  1. Place the ignition switch to the OFF position.
  2. Install the HVAC control module.
  3. Connect all previously disconnected components.
  4. Start the vehicle.
  5. Wait 40 seconds for the HVAC control module to self-calibrate.
  6. Verify that no DTCs have set as current DTCs.
  7. Place the ignition switch to the OFF position.
  8. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  9. Rotate the Mode knob fully counterclockwise.
  10. Rotate the Mode knob fully clockwise.
  11. Rotate the Mode knob fully counterclockwise.
  12. Release the AC button.
  13. Wait 40 seconds for the HVAC control module to self-calibrate.
  14. Start the vehicle.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
David White 44 8834 1 22x Level Transit Package Logo
262 people viewed this question
Top David Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a David Measuring Tool and Sensor Expert? Answer questions, earn points and help others
