Question about DeLonghi PrimaDonna S Deluxe Super Automatic Espresso Machine
Empty circuit fill circuit insert water spout press ok
This error keeps popping up during setup procedure of a new coffee maker machine
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
When inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Posted on Apr 18, 2015
Need to restart setup. had a power outage before completing setup. what is procedure?
Here is a tip that I wrote about how to registeryour Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
KeurigRegistration, User Manuals, Cleaning, and Troubleshooting heatman101
May 28, 2011 | Keurig Elite B40 Coffee Maker
I have a Gaggia Titanium, I did descaling, had difficulty during the process. It shows ventilate. I have tried priming, but it doesn't pump water through the nozzle
Hi.
Disconnect and re-apply power (unplug power cord). After that try doing rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
See also: the ventilate error.
Regards.
Ginko
Apr 20, 2011 | Gaggia Titanium Espresso Machine
The spring and stopper allowing coffee to be poured during brewing fell off. Can it be fixed?
Hello camyernj,
The cone stopper has three parts. The plunger, spring, and collar. The collar is very small and sometimes twists or pops off. If you have these parts you may be able to fix it. If not, contact a small appliance dealer to buy a new cone. Hope this helps. Regards, NormanZ
Jul 14, 2009 | Cuisinart DCC-1200 Coffee Maker
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a cuisinart automatic grind and brew thermal coffee machine. Soemtimes, during brewing, the container holding the grinds pops open and the still brewing coffee pours everywhere.
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Jul 07, 2008 | Cuisinart DGB-600 Coffee Maker
DeLonghi PrimaDonna S Deluxe Super Automatic Espresso Machine Logo
2,436 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
