Question about Ovens
How to use the grill - Ovens
    Top Expert:
  • Ovens Master
  • 44,391 Answers
Grills are used with the front open
if it has a separate door open it, switch on the grill and select which tray level by the grooves in the side of the opening
closer up the hotter the cooking , the lower the more temperate setting
just turn on grill switch , open door and go for it.
Posted on Apr 13, 2015
Testimonial: "Is the grill the middle knob of 3 and do I need to use the oven knob as well. The grill doesn't work just using the grill knob"
  • Bill Boyd Apr 13, 2015
    the grill knob will be marked grill and if it does't get the grill coil element hot after turning on then there may be 3 faults --faulty switch, faulty thermostat and faulty element. Have an accredited electrician check it out
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 | Ovens
My grill on my cooker keeps going off and on... you cant grill cheese on toast as the grill goes off and the cheese goes cold?
We know that the grill element is working because it does get hot. It sounds like a problem with the grill control.
Feb 11, 2011 | Zanussi Ovens
How do i work the grill?
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
What is the chain on the side of my grill for? Kenmore Grill with 100% Infrared Cooking System Sold by Sears | Sears Item# 07116650000 | Model# 464222209
I have either the same grill, or one very similar (Kenmore infrared grill) and just assembled it yesterday and had the same question! I don't believe it's a safety chain. It hangs from the left front corner of the main grill body, and it has some sort of curled wire thingy on the end of the chain. The chain is definitely not thick enough to secure the grill. I looked through the assembly instructions a few times and could not find reference to what it's for. Any other ideas?
Jan 03, 2010 | Ovens
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
I have zanussi ZBS863 oven/grill but the grill not heating up as much as it used to and not cooking stuff properly, the outside part of grill still red but inside bar looks like it isn't working
It's a dual grill which uses the outside bar on full grill and /or oven. The innder is used on grill only. This part is open circuit and needs to be replaced.
Dec 07, 2009 | Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
