MY Sony KDL52WL140's standby light blinks 14 times. What board needs to be replaced to fix this issue. T-con, power supply or main board? Or is it none of the above?
Tv worked fine when I went to bed. Woke up and tried turning it on but it would not turn on. Instead the standby light blinks 14 times, pauses, then repeats. If you unplug the tv and plug it back in the "sony" lights up for a few seconds then shuts off and the standby light begins to blink. Is there a board that can be replaced to fix this issue? It is not under warranty so either I fix or I go with out. Any information would be appreciated.
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
SOURCE: My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Posted on Jul 14, 2010
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
gopakumarg43
  • 74666 Answers
SOURCE: sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Posted on Nov 13, 2012
Sony Bravia KDL 50R550A six blinking light issue.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 21, 2017 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
I have a Sony KDL55W900A that shuts down after about 1 min and then the logo blinks 4 times, I have replaced the T Con Board and that did not fix the problem
Denotes a power supply regulator failure. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 18, 2016 | Sony Televison & Video
I GOT 14 BLINKING RED LIGHTS SONY BRAVIA KDL46VL160 I DISCONNECTED T-CON BOARD AND THE GREEN LIGHT STAY ON I ORDER USED T-CON BOARD TWICE INSTALLING AND AGAIN I GOT 14 BLINKING LIGHTS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
May 23, 2016 | Televison & Video
Green power light on then standby light blinks twice over and over
hi
there is a problem in main board mean ip1so please replace the main board
Jan 06, 2016 | Sony KDL40S5100 40 in. HDTV LCD TV
Why does th3 Standby light blink 5 times on front of my Sony Braivo KDL-55ex620 TV.
HI
5 time red light blinking indicate that the T Con board is defective please replace T con but after replacing the t con board you must up date the SW because in some cases you replace the t con & 5 time is gone but there is no picture so in that case you must perform sw
thanks
Feb 14, 2015 | Sony Televison & Video
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 2000 Sony KP-53HS10 color rear video projector, Just yesterday it turned off in the middle of watching it and the timer/standby light merely blinks. When I unplug it and replug it in, the same...
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
  1. Open the back cover.
  2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
  3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
  4. If the power supply output is normal..The problem could be on the main board...
  5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
  6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope thissolution will be helpful..
Thanks for using fixya...
Jul 05, 2011 | Sony KP-53HS10 TV
Sony KDL-26s200 LCD 3 blinks from the standby light, TV wont turn on. THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also...
Look for Bad capacitors they will be swollen,vented or puffed up on Top this is the most common problemwith this set. 220uf 10v 330uf 10v 1000uf 16v 3300uf 10v
Jul 01, 2010 | Televison & Video
Display faded to black and standby light blinks 14 times. Sony support said it is an error code and I am trying to find out what the error code is.
14 blinks is a high frame rate error, you can check the LVDS cable connections first, if not work replace the T-con board, if still not work, replace the panel, but it is not worth the money to repair.
There are two different t-con boards for this model, part # 1-857-132-11 cost $270, and 1-857-240-11cost $200. It depends on the serial #, you need to make sure which one is for your TV.
Apr 12, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
