Question about Akai LCT3201AD 32 in. LCD Television
Set comes on back light comes on but screen is very din ,no picture is present.
  • dgreen954
    dgreen954 Apr 14, 2015
    when first got this set the T CON board was bad,the set was fine after replaceing the board. I lent it out to a friend 2 months later they brought it back not working.All voltages from the power supply aregood,i even replaced the main board after finding a bad cap on it.Still no picture. You can see the back light is lit but you can turn out the lights and see the screen lit but no picture is present.
Westinghouse sk-32h570d sound no picture
After ignition of the back light, a control voltage will come from the main board, to control the intensity of the back light. This is true to all LCD TVs. You should check, whether this control voltage [a variable voltage according to picture displayed on the screen]. If it is not present, make sure that the main board is faulty, as this voltage is generated at the main board and send to the back light inverter board' to control the brightness. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 22, 2014 | Westinghouse Televison & Video
Screen is white blank 2 inches on each side of picture.
Switch to the an input that is not being used. The bars are present, go into the menu and reset the tv to factory settings. If the bars are present it would indicate hardware failure.
If the blank bars are not present on the other input, something is going on with the cord, or a setting in your set top box
Nov 22, 2013 | Toshiba 42HP66 42 in. LCD Television
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
Backup camera on double din stereo
You probably do not have the camera connected to the back up lights. That would be my guess.
http://stores.ebay.com/aquaruimproductsandmore
Aug 24, 2012 | eBay Auctions
When we switch on our Sony Trinitron, the red light keeps flashing, audio comes on but it takes a very long time 3 min approx for the picture to show up. Also the clarity and colour of the picture has...
This could be a sign of hte picture tube failing. If you are comfortable accessing the set with teh back removed, try a screen adjustment as follows:
1) locate the flyback transformer (part with large red wire coming out the top)
2) There should be 2 adjuistments on that part labeled screen and focus.
3) turn the screen control clockwise just a bit
If the set comes on more quickly, than the tube is starting to fail. The adjustment above is a temporary "fix" that will get you time to locate a replacement only. Further adjustment will cause the picture to be washed out and may show retrace lines as well.
Hope this helps,
Dan
Aug 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
Power light comes on but no picture. Black screen
if the set appears dead ecept for the power light, unplug the power cord from the back of the set, wait two minutes, then plug it back in and try to turn on the tv. Doing this worked for me.
Jan 27, 2010 | Sanyo DP42746 42 in. Plasma Television
Dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
