Question about Northstar Electrical Supplies
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
In power. The lights dimmed and a/c and refrigerator stopped. Meter was showing 120 volts output and all breakers looked good on control panel. Shut down generator, let it rest for about 3 hrs. Restarted, everything ran fine for about 5 minutes when the same problem happened. Any ideas of what the problem can be?
    Top Expert:
  • Northstar Master
  • 42,671 Answers
The unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Posted on Apr 13, 2015
We are about to have a hurricane. How long should I run our generator to maintain proper temperature in a whirlpool upright freezer model EVL201MXRQ03 and kitchen aid refrigerator model KSRB25FHBT04?
The best choice would be to power it for about 2 or 3 hours several times throughout the day.
However, I was able to keep 3 houses running with no loss of foodstuffs by doing a 8 hour on and 16 hour off cycle for each.
Just be sure to leave the doors closed so you do not let the heat get inside.
Be certain you have the generator outside so no one gets carbon monoxide poisoning from the exhaust fumes.
Also, remember, leaving it outside could cause it to "disappear" into the hands of a thief !
God bless your efforts.
Sep 05, 2017 | Whirlpool Refrigerators
WHY THE HIGH WARNING BUZZER IS COMING ON OFTEN
Good Afternoon Friend, thank you for your question!
Typically the buzzer/alarm will sound and the red light, if equipped, will also glow if the temperature of food rises to an unsafe level. Did your refrigerator previously experience a power loss? If you buzzer is sounding, you can deactivate the alarm of your refrigerator by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the relight/alarm should go off on its own. If the red/light alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best! - Z
Sep 07, 2014 | Frigidaire Refrigerators
Www frigidaire com
Hello Friend, this is Z. Thank you for your post!
I see that your question is listed under Frigidaire refrigerator (FPRH19D7LF) and that the alarm is sounding. First, did your refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best!
Sep 03, 2014 | Frigidaire FPRH19D7LF
HIGH TEMPERTURE MESSAGE FOR FRIDGE AND FREEZER
Hi Friend, this is Z. Thank you for your post!
Did your Electrolux refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. Is your refrigerator beeping or did the alarm turn on? If so, first deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best - Z
Aug 27, 2014 | Electrolux Refrigerators
Keeps sounding an alarm on refrigerator side and will not cool
Hello Friend, this is Z. Thank you for allowing me to assist you!
Did your refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. It is good to wait roughly ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best regards!
Aug 17, 2014 | Frigidaire FFHS2622MS 26.0 cu. ft. Side by...
LFFU14F5HWL how do I know if the control panel is bad I hear a beep and a small red light but will not turn omn
Hello Dan, I am happy to assist you!
Did your refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your appliance. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Jan 30, 2014 | Frigidaire Freezers
How do I disarm the power fail alert ?
Hi joeeshir - Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Apr 14, 2013 | Electrolux EI26SS55GS Stainless Steel ...
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Travel trailer refrigerator will not get cold
Model 2652 Refrigerator The fridge has been perfct till this last trip. the auto light is on and its not getting cold no red lights and i have pluged in as well as unpluged propain is full but i see some yellow dust inside the big cyinder.we may have left the frezzer door open for a couple hour.
Jun 04, 2009 | Dometic RM2652 Refrigerator
Electrical Supplies Logo
182 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
