Question about Tools & Hardware - Others
When aplying fresh paint with roller paint is peeling back of with roller
  • 4 Answers
What is the substrate? (plaster, drywall, painted surface.... etc.)
if the surface is painted: can you tell the generic type of paint used before? and what is the condition of the existing paint, is it chalky? did you try to sand it?
if so, you might need to sand it and remove all flaking and chalking paint prior to application of a new coat. you might also need a compatible primer for best results.
Posted on May 05, 2015
Peeling paint on cinderblock walls in basement
Just a guess, but it is likely that moisture is causing the paint to peel. I suggest you remove as much peeling as you can with a wire brush and then use a waterproof sealant. I had very good luck with a product they sell to seal cement walls in basements with moisture problems.
Mar 09, 2015 | Cars & Trucks
How to reattach headliner trim around driver side window opening on 2001 vw beetle
You are better off just peeling off the fabris and painting the liner with a flat paint. That is what I did. I tried to spray glue it and it just kept peeling back off.
Feb 28, 2015 | 2001 Volkswagen Beetle
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
What can i do to fix peeling paint on a wall?
scrape, sand, Prime with an acrylic primer ,skim texture and top coat
or call a professional
Jun 25, 2014 | Tools & Hardware - Others
My weber genesis silver-b (sku # 218446) is 11 years old and has this "peeling problem". Is anyone "sure" that it isn't "paint/enamel" that is peeling on a model that was...
I'ts the same today as it was back then. They still use porcelain enamel. Not paint. A couple of things that could ease your mind. Paint has like a kerosene smell to it. Also, drop a chunk in water for a few days, paint will not dissolve in water.
Jan 18, 2011 | Weber Genesis Silver C Grill
Paper jam indicated. Unable to clear.
please your printer toner is out of printer and
so in paper ? check the aply paper tray in fixed paper ?
and out print roller behind paper fixef ?
and aply power is on and aply print test?
Sep 22, 2009 | Epson Stylus Photo 1290 InkJet Printer
Paint peeling
The paint you need is called microwave cavity paint. If they don't have it at your local hardware store, you may get it at www.appliance411.com/data.php?rc=277
Be sure to sand the area first with some emory cloth to remove any loose paint flakes.
May 07, 2009 | Rival MT660 Microwave Oven
Peeling paint
The only real danger is if it continues, it can deteriorate the metal, allowing sparking and possible leakage.
It's a good idea to clean, sand, clean again and repaint the area.
High temperature appliance paint is available form stores like Lowe's and Wal-Mart.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Hotpoint RVM1635 Microwave Oven
Peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Nov 02, 2007 | Rival MT660 Microwave Oven
Tools & Hardware - Others Logo
174 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
