Question about Garden
When I put the lever down the blades do not engage
    Sergeant:
  • 462 Answers
Need adjusted or belt loose
Posted on Apr 23, 2015
Husqvarna Riding Mower when turn lever blade will not engage.
If the engagement is done by lever, yes it is controlled by cable. It could be disconnected or the cable could be broken.
Oct 29, 2016 | Husqvarna Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
How to fix a PTO (blade engager) lever on craftsman riding mower 2000LT
cable is broken down by the deck... most likely
or it is broken by the handle... also most likely
belt engagement arm is stuck... also likely
Aug 29, 2014 | Garden
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
Apr 01, 2012 | Garden
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Blades will not engage
Lever that adjusts height does not make blades turn. You need to engage the blade lever and if you can not tell if the blades are turning then they probably aren't. check belt it could need replacement.
Apr 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
