Question about Food Mixers
Oil leaks on food. How can I fix it? - Food Mixers
  • Food Mixers Master
  • 1,305 Answers
Make and model would be a great help.
Posted on Apr 13, 2015
Is there place on the ksm90ac mixer to add oil
No there isn't, the oil that's leaking out is the liquid that makes up part of the grease that's in your gearbox. Grease is solids and oil combined, over time the mixture breaks down and releases the oil. A proper fix if you wish to do it is to dismantle the machine, clean out the old grease and replace it with new. The oil that's leaking is harmless as it is special food grade grease in there. If you choose to replace the grease you should be buying and using KitchenAid food grade grease. A KitchenAid service agent will have the grease and be able to do the job for you.
Dec 20, 2017 | Food Mixers
Why is oil leaking down into the mixing bowl on the Hobart HL200 Mixer
There is a leaking gasket. The OIL is from the Grease applied to the gears. It may have somewhat turned a portion of lube to a liquid state due to heat within the motor housing during use. The OIL as you put it, could also leak out from the port where you insert the beaters. If so there is also a set of seals to prevent that from happening, and if they are worn or damaged, leaking can occur. This unit needs a professional serviceman to fix the problem.
Feb 03, 2015 | Hobart HL200-1STD Mixer
Mixmaster is leaking oil from the beaters
Here is a link on YouTube. It may not be for your model but it can give you an idea: http://www.youtube.com/watch?v=8eKHVvNX5eY
How to Fix KitchenAid Stand Mixer That Is Leaking Oil
Apr 04, 2014 | Food Mixers
Leaking oil
There are only two places where Food Grade Grease is used: In the
Transmission Housing (normally installed with a gasket) and in the Planetary
Assembly (Agitator gear). Over times, the grease will get hot and turn into liquid.
The Beater shaft has an O-ring to prevent oil from leaking down, but there is
nothing to prevent oil from the Planetary from making its way down your mix.
Depending which model you have, it's time to open up your mixer, clean out
all the oil and replace it with fresh Kitchenaid Food Grade Grease.
Jun 25, 2011 | KitchenAid Food Mixers
My mixer is leaking oil. How do I fix it?
Your mixer is leaking grease not oil. It is a simple fix. First you have to open the machine and regrease it. Once you have done that try replacing the gasket. Also, this particular mixer cannot be left on its side (some people store it sideways in a cabinet or under the sink) doing so will cause the machine to leak as well.
Oct 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
Oil leaking
Sep 30, 2008 | Spar SP200 Commercial Planetary Stand...
Hobart h600 60qt mixer leak oil
call me. 626-579-3580. Ill fix it.
Mar 25, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
61 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
