Question about Panasonic Audio Players & Recorders
My Panasonic sa-954 won't change disc keep getting error message
SOURCE: I have the panasonic SA-PT960.W1 keeps flashing
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Posted on Jan 03, 2010
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
technical114
  • 1851 Answers
SOURCE: Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Posted on Nov 16, 2010
Ezrahite
  • 2632 Answers
SOURCE: I have a Panasonic
Welcome to Fixya. This is a known issue a HDMI problem or connection problem. You can try the steps below and see if it will fix the problem
- Unplug and plug in after few minutes, say 30 minutes. Check if that would fix the problem.
- Make sure all the Connections are well secured.
- If doesnt work try to change the cable and see if it will be able to fix the problem.
If your using a Player
- make sure that the red, green, and blue ports on the DVD player connected to the yellow, red and white port on the TV.
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 16, 2011
Hello. I have a panasonic sa-ak45 and drive left open, what happens is that when you press the button open / close it just displays the message "changing" and never goes out of disk 1. It will be a...
The disk jumped from the internat platform , you must open the back case and push the CD a little. He is stucked somewhere betwen. It's very easy . just 12 screws
Sep 02, 2010 | Panasonic SCAK410 5-Disc CD Changer
Panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Aug 26, 2009 | Televison & Video
No Disc
you need to replace the laser/optical
Dec 07, 2008 | Panasonic SA-HE70K
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
My panasonic SA-AK750 hi fi stereo keeps saying disc change error and the changer will not open or change disc. ive tried turning it off at the wall and then turning it on again but its still displaying...
Tienes que llevarlo a un centro de reparaciones ya que el sistema de cd esta fuera de tiempo por eso no funciona nada.Hasta que no lo pongan a tiempo no va a funcionar.
Apr 06, 2008 | Audio Players & Recorders
When we try to play a disc frpanasonic sa-ak28
CD lens may be defective or just need cleaning.
Dec 10, 2007 | Panasonic SC-AK33 CD Shelf System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
49 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
