Question about Casio Office Equipment & Supplies
How to load paper roll into calculator hr100te
SOURCE: Canon P23-DHV Calculator
I got this solution from someone else who had a problem. Just feed the paper in through the back of the unit into the ****. You kind of have to be persistent in guiding in and hitting the "feed" button at the same time.
Posted on Jul 25, 2008
SOURCE: BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Posted on Oct 31, 2008
SOURCE: Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: How do you load paper roll on Sharp Calculator
print
Posted on Jul 02, 2009
RonPark
  • 855 Answers
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Posted on Sep 26, 2009
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
How do you load the paper on this adding machine?
    • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
    • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
    • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
    • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
Jan 30, 2011 | Canon P23-DHV Calculator
How do you load the paper?
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Aug 31, 2009 | Canon P23-DH Calculator
Cannot load new roll of paper
It is actually quite easy.
1. The calculator should be powered and be "on" and the removable plastic should be affixed in its normal position (from this the paper emerges and the plastic is serrated to tear the paper when it comes out).
2. Take the roll of paper and put it on the spindle with the paper rolling toward you from under. Take the leading edge of the paper and physically lead it into the horizontal slot in the back of the calculator, and press the "arrow-up" button (on the upper left of the board) repeatedly until it catches.
For some reason, Canon does not make the manual available on line.
Jul 06, 2009 | Canon P23-DHIII Calculator
Apr 09, 2009 | Sharp EL-1801C Calculator
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Paper Loading
Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
Oct 18, 2007 | Canon P23-DHIII Calculator
82 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
