Question about Dell Office Equipment & Supplies
My dell v720w ill not print. I re-installed all new ink. I sill will not print.
  • Official Brand Answer
  • 560 Answers
Anonymous,
Try uninstalling the printer drivers and then reinstall the printer drivers back into the computer. You can download the drivers from the link below.
Dell Printer Drivers
http://dell.to/1b4vbUu
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Apr 17, 2015
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
Brand new dell v313w printer printing blank pages
When you put the ink cartridge in the printer did you remove the protective cover first?
Jan 16, 2013 | Dell V313w AllInOne InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    How do I install the printer cartrige? I do not have the booklet...
    1. Turn on your printer.
    2. Open the front cover.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press the tabs on the cartridge lids, then lift the lids.
    1. Remove the old ink cartridges.
    1. Store the cartridges in an air-tight container or dispose of them properly.
    2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
    1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
    1. Snap each lid closed.
    1. Close the front cover. The front cover must be closed to start a print job.
    1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
    2. Click the Maintenance tab.
    3. Click Install a new print cartridge.
    4. Click Next.
    5. Select the type of cartridge you installed.
    NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
    1. Click Next.
    Dec 17, 2010 | Dell Inkjet 720 Printer
    Printer is not printing
    hello...........
    It seems this is a problem of ink.....
    Try to get a new cartrage................
    If that is ok then check the driver whether it is install or not.............
    If that dont work let me know ill give you detailed instruction .........
    happy computing
    Jun 21, 2010 | HP LaserJet 1020 Printer
    Dell 720 won't print color, color ink cartridge missing
    check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
    Sep 13, 2009 | Dell Inkjet 720 Printer
    Dell printer
    Assuming you have used a Dell approved ink cartridge the problem is most likely just a dirty print head. If you haven't printed for a while (which can be only a week or so in hot places) you may have to run the cleaning process 5-10 times or more before you start to see marks on the paper. This is typical of all ink jets that are not used regularly. If you can not get it to print or it will not get good enough to print you can resort to manually cleaning the print head with a qtip dipped in viniger which disolves most inkjet inks. It won't take very much to clean and it will print like new.
    Jul 09, 2009 | Dell 922 All-In-One InkJet Printer
    Dell 922 All-In-One Printer will not print anything
    The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
    Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
    Installing ink cartridge
    I've had this problem too. The only way to make the message go away is to buy the ink from Dell. Although generic ink cartriges will work the printer will not/can not reset the "low ink" message unless you buy the cartriges directly from Dell. So you can use another brand, but you'll just have to overide the low ink message when it pops up by telling it to continue printing. Then you can tell when the ink is low by seeing it when it prints out.
    Sep 10, 2008 | Dell 924 All-in-One InkJet Printer
    Dell A940 smeared printing
    Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
    PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
    Maybe it will work for you! Good luck!
    Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
    49 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
