Question about Miscellaneous
It will not change the slides. Seems something to do with the motor. Any tips
  • Margaret Westerman
    Margaret Westerman Apr 14, 2015
    It had been changing the slides perfectly but then it stopped moving the slide holder on. It just keeps whirring and nothing happens.
  • Danny Kuhlmann Nov 23, 2015
    need make and model what is it?
A slide got stuck in the projector, and when I took it out the projector just died. No power. Any ideas about what's happened? Thanks
If this is a Kodak Slide Projector, there are 2 thermal fuses (1 is in the motor and NOT replaceable and 1 is in the area of the lamp). Almost ALL Kodak projectors had 2 thermal fuses as described. You need to determine the model, as that will determine which fuse or motor assembly you will have to buy & install to fix your projector. If its a Kodak, let me know the model and I can help you further! You can buy parts for Kodak projectors at: www.micro-tools.com.
Good Luck! Jim
Feb 04, 2013 | Office Equipment & Supplies
The van was hit on the back passenger side resulting in a dent . The open door light along with the interior lights flashed when I hit a bump. I hear something that sounds like a fan continuosly blowing....
I think this may be the "closer" motor continuously trying to gain a positive latch--and unable to do so. This could be from a damaged latch switch.
The sliding door has three motors, a slide motor, a release (or unlatch) motor, and a closer (or latching) motor. The open door light and interior lights coming on seem to indicate that the "closed and latched" switch is sometimes open-- allowing the closer motor to continue to operate.
Another possibility is that the dent has changed the geometry of the door mechanism especially the draw of the pull cable. The slide motor has a sensor that pulses when it runs. The door management controller counts the number of pulses of the slide motor sensor to determine when the door is fully closed and then stops the slide motor. At that point, the closer motor operates to latch the door. If the cable geometry has changed, the door controller may be shutting off the slide motor prematurely and the closer motor cannot complete the latch.
Mar 28, 2011 | 2000 Honda Odyssey
Carousel projector slide not working right. Can only see half of the picture on the screen.
I had a similar problem and was able to get the full view by giving the change button a quick touch for a partial activation. It seems as though the cycle does not complete before the motor is turned off at what should be the end of the cycle. I took it apart to find the problem but did not discover the correction. So the little "flick" on the change button finished moving the slide into position and the "blocker panel"(inside the projector)) out of the way so the whole slide could be seen.
Jan 13, 2011 | Vivitar V5000AF Slide Projector
Whirlpool Quiet Wash II - LSQ9010PW2 Machine works great but intermittently does not completely spin for larger loads. Seems like something is slipping.
you can check the motor coupling to see if it's rounded in the middle and check to see if there's any oil on the floor or around the tranny,you can slide the washer forwards around 12 inches and tilt it back and rest it against the wall and check with your hand to see if you can feel any oil on the tranny,or use a paper towel to check it.if it's the tranny you'll have to decide if you want to sink 300 bucks into this washer or buy a new one.let me know what you find.the coupling is behind the motor,pop off the two metal clips on the pump and slide it off the motor shaft,remove the two screws and clips on the motor and slide that out and you'll see the coupling on the back of the motor and the other half of the coupling will be on the tranny
Sep 03, 2010 | Washing Machines
The right side sliding door of my 2005 voyager is not workingat the begining trying to open it partialy worked mean the when i presed the the open/close button the door started moving but on a specific...
hi
this is because of the track in which the door slides.there is something in the path or the track got damaged which prevents the door sliding after a certain limit.
the wiring harness and the motor are seems to be in good condition becausethe door works til certian point.so the problem is with the track only.
if my answer was usefull please vote
Jun 27, 2010 | 2005 Dodge Caravan
I have a hobart 120 and it seems to short out when I pull the trigger, the rollers don't turn either. The unit just clicks
I'm not sure why you say it seems to short out. Does it trip the breaker? If the rollers aren't turning, but the tip will still arc, there is something wrong in your drive section. It could be almost anything from a bad drive motor to a bad switch in the torch (hand unit) to a bad controller. It will require diagnosing it with a voltmeter. Since it is clicking, the most likely thing is a bad drive motor as that click is probably a relay that is supposed to run the motor.
Dec 04, 2009 | Welding Tools
Passenger sliding door motor won't close door all the way.
I just fixed my 2005 T&C sliding door. The wire in the plastic rolling chain is broken when resides right under the step pad. It took me 30 minutes to fix.
Go to this link.
http://wiki.answers.com/Q/How_do_you_replace_the_power_sliding_door_wiring_harness_on_a_2005_Town_and_Country_chrysler
May 27, 2009 | 2005 Chrysler Town & Country
Kirby Ultimate G Upright won't stay up right
I figured out that when mine did the same thing, it was time to change the bag. It was too heavy for the handle to handle! LOL Hope that helps. Tracy
Jul 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Miscellaneous Logo
151 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
