Question about Bosch Drills
Bosch Turbo 11235EVS keeps slipping into drill mode while hammering.
Bosch Turbo 11235EVS keeps slipping into drill mode when hammering. Care must be taken so you don't sprain your wrist. I'm not sure if this is an electrical or mechanical problem. Which makes getting the correct part costly, if you can get the part at all. Funny, I usually only give answers but this time I'm sorta stumped. Dan
3 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 4 Answers
SOURCE: My Bosch hammer drill (electric) the chuck is slipping I can hold it in my hand and no torch
unplug it strip it down and you will find the problem
Posted on Aug 18, 2012
How to put together Bosch 11235evs rotary hammer
here you go the whole parts list.... good luck http://www.ereplacementparts.com/bosch-11235evs-0611235739-rotary-hammer-parts-c-128_1376_1380.html
Jun 05, 2015 | Bosch Drills
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
Bosch 11235evs power at switch but still does not run.
Chech the brushes they have a spring pin in them if they wear down to far. This stops the machine and prevents the armature from becoming damaged.If the pin has popped out you need a new set of brushes
Aug 11, 2010 | Bosch 11235EVS 1 - 3/4'' SDS - Max Rotary...
Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Jun 16, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
HAMMER MODE SLIPS OUT
i am guessing the transmission problem not enough tension to the clutch
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
246 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
