Need blower motor information for model CNPVP3617ATAABAA, S.N.4307X27103.
The heat wont work think its the fuse which one would it be
What is year--make--model? Are you saying the blower motor won't work? If so check the blower motor connector for voltage and ground. I can't look up wiring info without more information.
Feb 23, 2015 | Cars & Trucks
How do I change a heater blower motor in Chevrolet van
Well, More information would be helpful like the year and model of your van. Most blower motors are accesed through the firewall from my experience. I owned a 1978 Chevy G-10 .Please provide more model specific information. Thankyou
Feb 02, 2015 | Chevrolet Cars & Trucks
Motor won't turn on
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Ubhb-21j11sfdai: what motor should be in this blower? HP, RPM, Voltage, Amp?
If you have the motor from the blower, the information should be on the motor nameplate. If there's no nameplate or information on the motor. Then to get the correct motor for your blower, you need to call your local Rudd dealer or local parts store. Give them the model number and serial number of the Rudd unit and they should be able to help you.
Jun 11, 2013 | Ruud UBHC Air Conditioner
I need information on how to change my blower motor assembly on a 2001 jeep grand cherokee laredo 4x4 4.0
The blower motor is located under the right side of the dash in the A/C Heater housing. Disconnect blower cooling hose. Remove blower connector from retainer and unplug the connector. Remove the 3 blower motor screws and remove blower motor. Reverse procedure to install..
Jun 30, 2011 | 2001 Jeep Grand Cherokee
Room blower motor is not working properly and the blower motor housing is too hot to touch. When power is disconnected from blower motor, blower motor housing cools.
I would say the motor is froze/locked up, Need to buy a new motor, all the information is on the motor itself. if this motor does have a capacitor I would replace that first. Good Luck Tim
Nov 25, 2010 | Heating & Cooling
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
The blower motor resistor is out on my 2004 dodge stratus.
Hi my name is Allen!
The blower motor resister is located on the passenger side under the dash, it's mounted on the bottom of the A/C Housing.
If you bought the resister from the dealership you will need to make the hole larger for the new style resister so it will fit.
You should also replace the blower motor, because the resistance built up inside the motor is what damages the resister.
For further assistance contact me at FixYa!
Dec 29, 2008 | 2003 Dodge Stratus
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
