Need blower motor information for a Criterion Gas Furnace, model CNPVP3617ATAABAA, S.N.4307X27103.
  • 4 Answers
SOURCE: Fix for coleman rv furnace
Check all limit switches and check power to gas control
Posted on Jan 06, 2009
  • 24 Answers
SOURCE: Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Posted on Sep 30, 2009
  • 80 Answers
SOURCE: Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Posted on Oct 03, 2009
  • 87 Answers
SOURCE: My son has a ducane gas furnace that will not come
replace your flame sensor
Posted on Oct 06, 2009
  • 587 Answers
SOURCE: I HAVE A RHEEM CRITERION 2 gas furnace, when i
Usually a bad flame sensor will cause this problem.
You can either replace it or clean it with some extra fine steel wool.
Posted on Nov 16, 2009
My Rheem Criterion II gas furnace makes metal slapping noise when the blower comes on. It is not the blower or the motor.
Is there noise when the inducer motor comes on? The small motor that comes on first. It sucks the co out of the combustion chamber. It comes on first. Then the burner lights then the blower comes on. And the noise continues while it's running and doesn't stop till the blower stops? Is that correct? But it's not the blower wheel? Could it be out of balance and hitting the blower shroud?
Feb 18, 2017 | Heating & Cooling
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
Whatever side the cold air return stack enters into the blower unit of the furnace.
Mar 02, 2015 | Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
If it is @ the furnace, then it is in the blower compartment on the return side.
Dec 07, 2013 | Water Heaters
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
How do I get the covers back on my Rheem Criterion
Here is the manual for the furnace.
Make sure you do not have the panels mixed up..just saying it can happen.
Oct 23, 2011 | Heating & Cooling
I have a Rheems Criterion Furnace and the main blower does not kick on any more. The ignitor coil glows, the burners kick on along with the venting fan and stays on for roughly 1 minute. The main blower...
Yeah i would change out that board .Should be a 3 amp fuse so maybe as simple as that but if not a cycling blower motor is a tell tale sign of curcuit board
Nov 21, 2010 | Water Heaters
Rheem Criterion II Furane would not ignite
what you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Dec 25, 2008 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
