Question about Power Computers & Internet
Does this have a fuse that might need replacing after a power outage
  • 1,836 Answers
Most cases there are dry lead-acid batteries that have become old and have a bad capability, often that he only shortcoming here on Google search in your neighborhood in order, one set (usually two batteries to replace it is with sliding contacts, the batteries can be up to a 12 year long life.
There are oft primary fuses used this can be also printfuses because the most people can only discover the standard glastube-fuse that are find and build to the outside by a screw connector.
But even there can be placed fuse-resistors in the electronic print of the unit. sometimes 1 ohm and soldered a 5 or 10 mm higher in the print mounted vertical or with sometimes build with a porcelain bead on one leg.
just a few examples where to look in the print verily JJE need debugging as you like, one fuse exceeds and does not measure current flow in the fuse.
Does this have a fuse that might need replacing af - 25642999-4auiz11ye42f1uv20wtzncrn-1-0.jpg
Posted on Feb 17, 2016
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
There was a power outage and now i am am not getting no power
Without any power going to the TV, it's likely that the power supply has been fried. If you feel comfortable opening the set, you should check where the power plug goes into the power supply and locate the fuse. The fuse is a small glass tube with metal rings at either end. If you take the fuse out of the holder and hold it up to a light, you can see whether or not the filament (the little wire) is still connected. If it isn't, and if the area's black or brown, then the fuse is blown and needs to be replaced.
Jun 05, 2010 | Samsung PCN5425R 54" Rear Projection...
We had a power outage. TV and video both now dead. Changes fuses in plugs, still dead. Could the fuses in the appliances be blown ?
HELLO
Power outages can damage electronic items!
It is certain that the fuses in each of the units power supplies will be blown but I would recommend that you get both in for servicing as sometimes changing the fuses INSIDE and trying them again CAN cause more damage - and more cost to repair.
Better to be safe than sorry! (:-)
Oct 21, 2009 | Sony Televison & Video
Will not turn on. after a power outage.
HI. this will happen during most outages. there is a fuse located inside the power supply device that is used to power your unit. simply remove the cover off the power supply box, and replace the fuse inside. this will correct the issue.
***((Now, if the fuse is OK, and not harmed, this will confirm that the power supply has failed. It should be replaced in this case))
Sep 09, 2009 | Nintendo Wii Console
Automatic ice maker quite working after 7 day power outage
Check to see if the power cable is ok. If your unit has a fuse, you may need to replace that. Looks like the power outage might have fuzzed up the power circitry. If neither of the above works, then you may need to get the machine serviced.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Computers & Internet Logo
448 people viewed this question
Top Power Computers & Internet Experts
john smith
Sattech
Level 1 Expert
James Mcphee
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
