Question about Canon LBP2900
Usb port is not recognising the printer
Usb port of the computer is nicely working
    Sergeant:
  • 148 Answers
Have you installed the printer driver...?
The USB port will not recognize the printer until the driver in installed.
http://support-vn.canon-asia.com/contents/VN/EN/0900785701.html
Posted on Apr 17, 2015
    Master:
  • 359 Answers
Turn every thing off including the printer and the computer. then turn on the PC then turn on the printer then plug in the printer after it is on.
Posted on Apr 12, 2015
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
Usb device not recognised lexmark s405, tried all advice listed in google pages except petrol & lighter.
Have you tried using another USB cable? You can also try plugging the printer in to a different USB port in your computer.
Also, try to plug in the printer to a different computer, if it works then there's a problem with the USB port of your computer. If it still doesn't recognize the printer, it could be the USB cable that's causing the problem or the USB port of your printer. If that's the case and your printer is still under warranty, contact our technical support team to have the printer replaced. You can find the contact number at our site: www.lexmark.com.
Jul 05, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Hp j3680 was installed but now it cant be recognised on the usb port.
Check your USB ports and cable. If you have the unit plugged into a hub, try directly connecting to the computer. (A bus-powered hub is at higher risk but failures are known with both.) Try swapping to a new port (if you are already directly connected to the computer). Check if a known working device works in the port. Ports can burn out under some situations.
Try a brand new cable as well. In some cases, you might want to try unplugging the power connection as well as the USB cable to clear any issues on the printer.
I hope this helps.
Feb 08, 2010 | HP J3680 Officejet All In One Printer
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
Software installed for printer but computer not recognising printer when plugged in via usb
Some USB ports are specifically configured to the printer when it was installed in that USB port. When you try to print, in the Print menu, make sure that Name of the printer is your specified printer. you may have installed other printers before.
Aug 31, 2008 | HP Computers & Internet
Computer recognises printer but print requests not actioned
that happened to me with my cannon ip4300 so I installed the driver again so I had 2 drivers installed on the computer. The computer named the seconed instalation cannon (2) .
number 2 worked the first didnt.
so used number 2.
later deleted number 1 .still all ok
wierd but worked.
david267
Jan 27, 2008 | HP LaserJet 4L Printer
MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Nov 25, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Computers & Internet Logo
350 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
