Question about Pentair Kreepy Krauly Inground Automatic Cleaner
It doesn't cover the whole pool mainly just the sides. I always remove the hoses when finished.
    Master:
  • 359 Answers
That is just the way they work
Posted on Apr 12, 2015
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
Kreepy krauly wont move around the whole pool bottom
Kreepy's simplicity is one of its main benefits, but also creates a drawback in that there is little to do as far as any adjustments to improve coverage. It is mainly a trail and error process by adding or subtracting hose sections, and moving the hose weights around. Good luck with it.
Aug 17, 2013 | Pool & Spa
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
My kreepy keeps coiling at the deep end of pool and stays there what do i need to do so that it cleans the whole pool?
There are a couple of things that you can try to get your pool cleaner to cover both ends of the pool. First, use an eyeball diverter to make sure that your water flow is correct to make the pool cleaner function in the proper pattern. Your return lines could be pushing the cleaner only toward your deep end. Secondly, if your hose is connected to your filter at the deep end of the pool, it could be that your hose is not long enough to cover the entire pool. You might need to add hose lengths. You will also want to adjust your hose weights.
Jul 16, 2011 | Universal Kreepy Krauly In-Ground Pool...
I filled my pool with hard well water. I added salt, waited, then turned on salter system. Water is brown. Is this from the hard water? How can I correct this?
The brown water is from the well water used. For an average pool of 18x52 I would add 2-3 gallons of regular chlorine and filter filter filter
If you are using the pump that came with the intex pool you will want to blast the filter cartridge with the garden hose about every 12 hours so that your flow doesn't slow down too much
Jun 14, 2011 | Intex Automatic Salt Water System for ...
G4 keeps heading for and climbing the sides of the pool, always making a long run along the side walls of the pool. The bottom is not being cleaned. Have adequate lenght of hose. Diaphram has no holes....
If these pool cleaners are staying on the edge on the pool, there are two things that you can do to correct the problem. First, reduce the flow through the cleaner to the low side of the ideal range. Second, add a hose weight about 3 feet from the cleaner's head. That should correct the issue.
Apr 15, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
After two years of perfeft performance, the Legend Platinum start to misbehave. Whells runing at 23 to 25 RPM after cleaning the hose filter. Main pool filter runs at 23 psi, booster pump runs and pressur ...
If your RPM is low, you will need to increase pressure to the cleaner. If the sweep hose is laying on the side and not sweeping, you will need to adjust the screw that holds it on to get it to a gentle sweeping motion. It is also possible that you have too much hose weight on the pool cleaners sweep hose. Try removing some of the weight and seeing if that changes.
Sep 14, 2010 | Pentair White/Gray Legend Platinum...
Pentair Kreepy Krauly Inground Automatic Cleaner Logo
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
