Question about Honda 2008 Ridgeline RTL
My blower motor stopped working on my 2008 Honda Ridgeline.
I smelled a faint burning smell from the vent. I shut the truck off and since then, the blower fan doesn't come on. I have ground at the blower so the resistor is working, however, I do not have power and the fuse (21) is good.
  • 2 more comments
  • Jason Trimble
    Jason Trimble Apr 13, 2015
    The motor turns when I connect straight to the battery. I have a ground at the motor but no power is found there. The fuse (21) is good. Could it be the relay?
  • Raymond Richards
    Raymond Richards Apr 13, 2015
    If you have one, this would be a possibility. Can you trace to see if you have power to the switch? And is so going out of the switch? I think the power to the fuse is before the switch. Is there power to the fuse? It could be the switch.
  • Jason Trimble
    Fixed. I traced the power wire behind the console and found the wiring harness had power on one side but not the other. This is a common issue on Honda Ridgelines. The wire was burned on one side of the connection that had power but not the other. I bypassed the harness/connection and it now works.
  • Raymond Richards
    Raymond Richards Apr 20, 2015
    Congratulations, good work
    Master:
  • 379 Answers
The motor is blown
Posted on Apr 12, 2015
2005 dodge stratus rt has burnt smell coming through the vents
there's not a lot of different burnt smells it could B antifreeze A leeking heater core or yes you're absolutely right if the motors burning up it could smell bad too
Feb 04, 2014 | 2001-2005 Dodge Stratus 2DR RT Custom...
Smell of burning wires and then my blower stopped
I think you should replace the blower motor and (maybe) the blower motor regulator too.
Oct 27, 2013 | 2000 Chevrolet Venture
Replaced a resistor in chrysler 2004 town and country, now weird smell whe defroster is on... The front vents wouldnt blow out any air, just quit working. The rear vents worked fine. Now strange smell...
Pull the blower motor out and clean out the leaves and other vegetable matter that has gotten in there, it is burning off on the very hot blower motor resistor coils
Nov 05, 2012 | Cars & Trucks
Chevy Aveo strange smell and smoke coming through the vent with air conditioning on. Checked engine-OK. Turned up air conditioning full blast...after 30 seconds...little more smell and smoke it stopped...
If the blower motor is still working, that was not the problem-the strange smell might have been from some bacteria in the plenium, and the smoke may have just been the result of condensation from the evaporator in the plenium-keep an eye on it, but if the blower is working, I would not be overly concerned about it.
Jul 20, 2011 | 2005 Chevrolet Aveo
When I turn the heater on burnt plastic smell from vents
It could be your heater blower motor or the blower speed regulating reisitor.
Try different blower speeds, see if the smell goes away. Also if one or more speed setting don't work, it is more than likely it is the resistor, if no to the tests, it is more likely to be the blower motor.
Also check to see if the blower intake is blocked.
Mar 02, 2010 | 2007 Chevrolet Uplander LS Minivan
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Feb 04, 2010 | 1987 Dodge Dakota
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Heater not working
The problem is probably the blower motor resistor. I'm not sure where yours is located exactly. They can be on the firewall under the hood or some are near the blower motor under the dash.
Dec 23, 2008 | 2006 GMC Sierra 1500 2WD
2000 ford explorer fan blower only works intermittently
On ford vehicles the blower motor resistors are the most common problem when this happens.
Dec 20, 2008 | 1995 Ford Explorer
AC smells
Hi,is a good probability that the blower motor did get burned and that could be the smell,
Aug 24, 2008 | 2001 Jeep Grand Cherokee
Honda 2008 Ridgeline RTL Logo
135 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
