Question about Panasonic KX-TGA652B Cordless Phone 3 Pack
I have 3 phones that say line in use. How do I get this off
All of my phones have line in use. How do I get this off
    Master:
  • 379 Answers
Unplug the mane unit and reset it.
Posted on Apr 12, 2015
How to fix phone line problem
1. Check your connection. Make sure your phone is connected to the phone line.
2. Change phones. Plug a corded phone into the phone line where you are experiencing problems. If the problem is resolved, the problem might be your phone, not the line; if it's a portable phone, it could have a signal problem. Make sure to change phone cords along with the phone to rule out problems with a phone cord.
3.Disconnect all extra phone equipment that plugs into your phone line, including modems, fax machines and additional phones. Leave only one corded phone plugged into your phone line. If the problem still occurs, plug your phone into every phone jack in your home to verify the problem is throughout your home and not isolated to one outlet. If your problem was resolved by unplugging devices, attach each device, one by one, to see if the problem returns. If it returns when you plug in one device, you know your problem is with the device.
  • 4.Call from an outside line. You can call from a cell phone or another land-based phone line. If the problem still exists, the problem may reside in the phone lines outside your home.
  • 5.If steps 1 through 4 do not fix your phone line problem, call the phone company from an alternative phone line. Discuss the problem you are having with your phone line and all the steps you have taken to check the phone line for problems. Your phone company will probably call your phone line to run some diagnostic tests. Based on these tests, they can determine if the problem is inside or outside your home. If the problem is inside your home, you might need a professional to diagnose the problem using line-testing equipment. If the problem is in the line outside your home, the phone company is usually responsible for fixing the problem.
  • Sep 05, 2014 | Computers & Internet
    Line 1 and two not splitting
    You can find the combiner at Radio Shack Model: T07843 ' Catalog #: 55034722. It may only be online not in the stores.
    Dec 03, 2011 | RCA 25414RE3 Corded Phone
    Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
    The phone doesn't like something it's sharing a line with.
    First, check to see if the extension number on each phone is different. You may have two extension 11's.
    Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
    Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
    Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
    Line buttons showing wrong phone lines
    When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
    Carl
    Jun 22, 2009 | NorStar Meridian M7310 Phone
    Pluged in my phone line and the phone reads Error
    Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
    Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
    2 line phone rca 25205re1 only 1 line works not the rollover line
    Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
    You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
    Jan 14, 2009 | RCA 25205RE1 Phone
    Second line not working
    The phone will show that "line in use" message when it's not connected correctly.
    If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
    If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
    If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
    Dec 10, 2008 | AT&T E2562 Cordless Phone
    2 Telephone lines and one phone jack
    Most of the Cordless 2 line phone BASE UNITS have the connections on the back for line1/line2 or seperate line 1 and line 2 connection. If you have the type of phone with the line1/line2 jack you have to be sure that both lines are on the same wall jack, otherwise make sure the phone you purchase has seperate line jacks and you will have two phone cords going to the base unit.
    Jul 26, 2008 | Lands Phones
    Defaults to Line 2
    Do you have a second phone? Be sure that phone is not defaulting to line 1. With 2 lines and 2 phones, each phone defaults to one of the lines.
    Unplug the phones. Plug in the phone you want to default to line 1 using the L1+L2 jack. Now plug in the second phone.
    May 22, 2008 | RCA 25205RE1 Phone
    Message Indictator
    hi its hard to understand... the phone is connected to line 4 or not? if so and line 4 is dedicated to fax line then the fax tone is the cause of your confusion fax tone is different from a regular tone phone if the phone isnt connected to line 4 and only to all 3 ordinary lines - then the phone is getting a over volage from them and activates the light & messege alert my advice let it be you will start playing with it something else will go worng... good day
    Feb 19, 2006 | RCA 25414RE3 Corded Phone
    Panasonic KX-TGA652B Cordless Phone 3 Pack Logo
    46 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
