Question about Onkyo TX-DS787 Receiver
The protect mode is active what are the causes
What are the possible fixes
  • Official Brand Answer
  • 333 Answers
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals.
Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Posted on Apr 17, 2015
How do i know how to fix my 2000 volkswagen passat once it goes into limp mode
limp mode is activated by the ECM to protect the engine and the transmission. What you have if it is missing would not cause the problem as it would have been evident before the limp mode was turned on. Run the fault codes to determine which sensor activated the limp mode.
Jan 23, 2015 | 2000 Volkswagen Passat 4Motion
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
The protection circuitry has been activated 3 times consecutively and as a safety precaution, capability to turn on the power is disabled.
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 20, 2012 | Yamaha RX-V671 7.1 Channel AV Receiver
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Dec 11, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
Audiobahn DUB Mag Audio 2502 Amplifier
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Onkyo TX-DS787 Receiver Logo
113 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
