Question about Gateway Computers & Internet
Have a Gateway M285e laptop that the letter 'e' on the keyboard doesn't function. Will cleaning the keyboard resolve this issue? Thanks
    Master:
  • 359 Answers
It is possible that there is something sticky keeping the "e" key form working. Removing the key and cleaning around it carefully with alcohol or alcohol water 50/50 or 100% mix might free it up. Use Que-tips or something like that. try to clean around it first. If that does not work try gently lifting up on the key with a small screw driver or knife. You may hear a small pop. this could go either way for you good or bad, so be car full. then try cleaning around the spot ware the key was, gently replace the key.
You may also consider plugging in a cheep $10.00 key board and see if this works. I spilled a large drink in min and needed to use an auxiliary key board until I replaced the computer.
Posted on Apr 12, 2015
Pyrhyc
  • 2028 Answers
SOURCE: laptop keyboard not working
Random keys or a row of keys not working indicates that the keyboard is failing and needs replacing. Before replacing, you might try taking the keyboard off and cleaning the connection. A little dirt or corrosion built up might cause this, but most likely the keyboard has malfunctioned.
Posted on Jul 23, 2008
Pyrhyc
  • 2028 Answers
SOURCE: 7330GZ Gateway laptop keyboard doesn't work
There is one thing you can try. Uninstall the drivers for the keyboard from the device manager, then reboot. The machine will find the keyboard and reinstall the drivers automatically. If this doesn't work, then I'm afraid the Shift key function has failed and the keyboard will need replaced in order to fix it.
Posted on Aug 25, 2008
  • 16 Answers
SOURCE: What Fn Key enables the keyboard to type letters instead of #s
use fn key plus numlk key
Posted on Jan 13, 2009
  • 135 Answers
SOURCE: Laptop keyboard prints wrong characters
Go to Control panel.
Select Regional and Language Options
In the Regional options tab, select your country and language settings
Click on apply and ok.
You MAY have to reboot for the changes to take effect.
Thanks for using FixYa and please rate this reply if it has helped.
thank you.
Posted on Feb 26, 2009
  • 3940 Answers
SOURCE: On a Gateway laptop, the keyboard always
Press Fn Plus the Numlock key that should turn the numlock off
Posted on Oct 05, 2009
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
HOW TO RESOLVE NONFUNCTIONAL KEYS ON MY NETBOOK?
Hi There,
Do you mean that the keyboard is not working as in, let's say the "enter" key doesn't function, or other keys do not function?
Or do you mean that there are specialized keys (usually media keys) on your netbook that don't seem to function?
If it's the latter, download the media keys application provided by the manufacturer here - http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2262
If the former - purchase a new keyboard. Replacing a keyboard is fairly easy on netbooks and requires little to no skill other than unscrewing four to eight screws. - http://www.ebay.ca/itm/Acer-Emachines-eM350-EM-350-NAV51-NAV50-SERIES-NETBOOK-US-keyboard-/160655260194
Jul 18, 2012 | Computers & Internet
One letter on keyboard does not work
if this is a pc and not a laptop pop the key out and press the pad under neath to sea whear the problem is
Oct 28, 2009 | Gateway 2520915 Keyboard
The letter d sticks on my gateway laptop. I use air can..clean it with alcohol swabs. Its relatively new kp..about 8 monyhs old
You should be able to pop off the key and then see if the problem in in the key mechanics or with the pad itself. Either way, using alcohol swabs could fix the problem.
Jun 12, 2009 | Gateway 2520915 Keyboard
External keyboard messing up Gateway settings
You have to unlock the FN key on your keyboard. It seems to be locked in place. I had the same problem and resolved it by looking for a "num lock" , "function lock" or actual blue image of a lock on the keys. Mine is located under the "Scroll" button. Press this along with the FN and your keyboard should go back to normal
Apr 15, 2009 | Gateway 2520915 Keyboard
Letter key button on my acer aspire laptop does not function
with a compressed air can be sure to clean everything inside the keyboard.
Let me know if it's enough and don't forget to rate the solution.
thanks
Jan 11, 2009 | Acer TravelMate 2300 Notebook
Letter
The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Keybord problem
I suspect someone at some time has spilt water on it and corrosion has set in you will need to have someone remove and clean it or fi a nnew one
Aug 06, 2008 | Computers & Internet
Mt3705 keyboard problem
You probably have the function scroll button on. See the blue numbers on the letters? press function scroll to take it off and see if that is your problem.
Jul 23, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
