Question about Simer Plumbing
Fix crack in housing simer 3110p pump - Simer Plumbing
    Master:
  • 379 Answers
What is wrong with the crank? is it a shear key or is it bent? I need more information.
Posted on Apr 12, 2015
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
I am getting oil out of the pump. Can this be a leak of coolant and can it be fixed.
I am sorry to hear your getting oil, this is not a good thing. If you remove the pump from water and disconnect it from any power source, try removing the lower housing and take a look around the impeller if you can. If the leak is coming from around the edge of the main housing your in luck, it is probably the main seal that can be replaced without too much trouble. If the housing is cracked or leaking near the bearing I am sorry to say it would be best to start looking for a replacement pump.
Mar 08, 2011 | Simer 1/6 Hp Submersible Utility Pump
Pump Housing is cracked. Can I replace the pump housing only?
To the best of my knowledge the housing is available seperatly but it is not cost effective in my estimation. I would try to use a epoxy type glue such as pro-poxy 20 or J.B weld and try to repair it. Hope this helps you and thanks.
Jan 02, 2011 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
How do I wire a Simer 2hp pump for 220v?
If it is capable of operating on 220, a diagram should be on the inside of the cover plate or the on the nameplate
May 29, 2010 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
Model 2305 pump. Housing is cracked. Can I buy
since the pumps cost is only about $40 i doubt that they make after market housings for it and i could not find any
Sep 25, 2009 | Simer 1/6 Hp Submersible Utility Pump
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
Hammering sound at shutdown
it has a check valve to keep the water from going back into the pit when it shuts off, depending on how high the pipe goes up when it stops pumping the water closes the check valve in which the noise, unfortuintly there is no quick fix, even changing the check valve it could still make the sound
Apr 15, 2009 | Simer 3/4 Hp Stainless Steel Sump Pump
Plumbing Logo
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
