Question about Scuba Diving & Snorkeling
Don't have decode mask - Scuba Diving & Snorkeling
Tip
3 activated carbon Mask mask DIY
Activated charcoal - not to be confused with plain charcoal - has become a common ingredient in skin care products, due to its deep-cleansing properties. It can be found in facial soaps, masks, liquid cleansers, and even in makeup primers with the purpose of preventing your skin from getting oily. Activated charcoal, which is a form of processed carbon, has an adsorptive quality that allows it to bind to dirt, oil and environmental pollutants, lifting them from the skin. It's inexpensive and easy to find at pharmacies and health food stores, usually in the form of capsules or loose powder. You can mix it with your face cleanser for a deep cleanse or use with other ingredients to create simple, effective facial treatments.
Warning
Activated charcoal may stain your clothes. Before preparing any of these face masks consider changing your clothes. Make sure to wear something you don't mind getting dirty when you apply the mask to your face. If your clothes get stained, rinse them right away.
1. Gentle purifying mask
Quickly detox your pores with this easy-to-make mask, which harnesses charcoal's absorbing powers to remove impurities from your skin.
Things You'll Need
Activated charcoal (1 capsule or 1 Tbsp)
Aloe vera gel
In a bowl, mix 1 tablespoon of aloe vera gel with the content of 1 capsule of activated charcoal until it creates a smooth paste. Apply to the face avoiding the eye area. Keep the mask on the skin for 15 minutes and then rinse off completely. Repeat twice a week for optimal results.
2. Purifying Mask for Blemish-Prone Skin
Want to banish pimples? Use this purifying mask to prevent blemishes from becoming the bane of your existence.
Things You'll Need
Tea tree essential oil
Face oil (carrier)
Mix the content of 1 capsule of activated charcoal with 1 tablespoon of facial oil (like jojoba or grape seed) and 2 drops of tea tree oil. Apply to the face avoiding the eye area (tea tree can be irritating to the eyes). Keep the mask on the skin for 15 minutes and then rinse off completely. Repeat twice a week.
3. Deep Cleansing Mask
Clear your pore with this ultra-deep cleansing mask.
Things You'll Need
Clay powder
Face oil (carrier)
Face mask brush or mixing tool
Mix the content of 1 capsule of activated charcoal with 1 teaspoon of clay powder (choose the best one for your skin type), and 1 tablespoon of face oil, like jojoba or grape seed (you may also use avocado oil or olive oil). Apply to the face avoiding the eye area. Keep the mask on the skin for 10-15 minutes and then rinse off completely. Repeat up to twice a week.
on Mar 21, 2017 | Health & Beauty
Cannot re-register Vertus Fluid Mask software, which I already own
Hi aaliceronm,
Please follow the instructions below on how to register/activate your Vertus Fluid Mask software.
Vertus Tech provides two ways of registration/activation:
Fluid Mask 2.0: In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three months).
Fluid Mask 3.0: For Fluid Mask 3 they offer two ways of registration and activation of your full Fluid Mask license:
Online registration:
This option requires an active internet connection on the machine on which you are installing Fluid Mask.
1. If you already installed the trial version of Fluid Mask please open Fluid Mask and go to > Help > Register.
2. Fill out the registration form and insert your serial key. The serial key should have been sent to after you placed your order for Fluid Mask 3 and has the format
01AXYZB0B123F123CDA7121234567AF123
Please make sure you copy/paste the serial key into the serial key field to avoid typos or mixing up digits and letters like 0 and O etc.
3. Click on the button to send the information.
4. The registration takes a few seconds. If it was successful you will see a pop-up window confirming that you are now registered.
5. You can either copy and paste your information from there into a file or to create an e-mail.
6. In addition you can see the message "You have a full license" when going to > Help > About Fluid Mask.
Registration by e-mail:
3. Click on the button to send the information. The registration takes a few seconds.
4. If Fluid Mask cannot detect an active internet connection or could not complete the registration for other technical reasons, then Fluid Mask will display your registration information in a new window.
6. Please send the complete information displayed to registration@vertustech.com. It is important that the information we receive is complete and correct.
They will process your registration as soon as possible and provide you with a license code by e-mail. You can then use this license code to activate your full Fluid Mask license under > Help > Register in Fluid Mask 3.
^return to top
Do I need an active internet connection?
Fluid Mask 2.0:
In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three month).
Fluid Mask 3:
Fluid Mask 3 does offer an online activation. For those users who don't want to connect their workstation where Fluid Mask is installed to the internet we offer an activation by e-mail, too. Instructions are displayed in the software during the registration process.
Hope it helps.
Thank you for using FixYa.
Jun 30, 2011 | Computers & Internet
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Flash
Dear Sir,
Try this link......
http://www.flashrespect.com/quick-mask-animation/
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 06, 2008 | Macromedia Computers & Internet
Scuba Diving & Snorkeling Logo
588 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
