Question about Water Water Heaters
Woks o k but wrong way round
Select for hot water get central heating ..set for central heating get hot water
  • 1,977 Answers
If this is a new hook up some one has got the two water pipes hooked up on the wrong sides If it works that way might be as simple to use a black marker then remark each side. Save a lot of work as well someone won't make a mistake some day and get into trouble.
Posted on Apr 12, 2015
I can get hot water but central heating will not come on. The radiator sign on the boiler is flashing all the time
there might be a problem. flashing lights meaning there is something wrong in either wiring or heating coil. some are equiped with manualy reset system. or some solinoid or contactor or a motorized valve. scaled water sensor or stuck float swithes.
Oct 25, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
When I have central heating on, why do I also get very hot water in taps even though water heating switched off?
This could be due to incorrect installation, incorrect wiring of controls, or an unintended consequence of combined central heating and hot water supply.
Nov 27, 2015 | Water Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
On a back boiler central heating system my hot water works fine but cant get my central heating working i have changed the pump there are no motorised valves on the system i have checked the the expansion...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
May 09, 2011 | Water Heaters
Water Heaters Logo
57 people viewed this question
Top Water Heaters Experts
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
