Question about Maytag Washing Machines
I bought a new Maytag washer and it will not fill with water properly on any cycle I select?? Do I just need to return it to the store?
    Genius:
  • Maytag Master
  • 1,585 Answers
Dont mess with it return it if u mess with it ure g/t is void
Posted on Apr 12, 2015
  • Maytag Master
  • 473 Answers
If new--less than 1 year--call for service. Everything should be free. may be a simple water valve replacement. Easier to replace valve than complete machine but its up to you.
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
jsrock516
  • 5911 Answers
SOURCE: screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
Posted on Feb 28, 2009
beltronic205
  • 1466 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    TheMobilian
    • 8220 Answers
    SOURCE: My washer fills with water and keeps filling
    The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
    Help my washer is overflowing !!!
    Posted on Jan 07, 2011
    Washer starts while water is filling
    From the research I did on this problem, it was suggested the water level/ temperature control valve was bad. I bought a new one and replaced it today. That was the culprit. I looked on you tube for a video on how to replace and it was a five minute job. The part was $85 but can be found cheaper on the internet. While at the parts store a guy heard the part I was asking for and immediately asked if I had a Maytag. Apparently this is a common problem with this line of washers. I also found out that this problem is caused by opening the lid after the cycle is started. Word to the wise, gather all your laundry then start the cycle. If you have something left over, leave it for the next load unless you have a stack of money lying around.
    Jan 23, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
    My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
    Bonnie,
    NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
    Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
    Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
    Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
    I m using maytag pav2200agw after fill the water washer is working fine but during the spin dry cycle water pump does pump out the water and start spin but the tub is not moving its not working propperly...
    I WISH I HAD SOME ANSWERS ON THIS ONE, BUT IT SOUNDS LIKE YOUR PUMP MIGHT NEED REPLACING. HOW OLD IS YOUR WASHER? IT WOULD BE CHEAPER TO BUY A NEW WASHER. BUT IF IT IS THE PUMP, THEN YOU CAN BUY A NEW PUMP FROM WHERE YOU BOUGHT YOUR WASHER. GOOD LUCK.
    RODNEY
    May 12, 2009 | Maytag PAV2300 Top Load Washer
    Cold water will not stop filling during rinse
    while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
    Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Waher fills and then quits, won't start the wash cycle
    LAT7300AAW that is your model number AZ103872 FD that is your serial number
    Jan 02, 2009 | Washing Machines
    Cold water will not shut off at end of spin cycle
    electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
    Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
    Feb 21, 2008 | Washing Machines
    Washing Machines Logo
    37 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
