Question about Kitchen Ranges
The unit stopped powering on. Just before it stopped, it work sometimes on the first try, then on the second or third now not at all. It has power. Thank you. Tom H.
  • 2,402 Answers
Is your motor wearing down? It sounds like it needs replacing.
A worn out motor will try to run for a while then finally just give up and quit.
Posted on Apr 12, 2015
  • Tom Hosler
    Tom Hosler Apr 12, 2015
    Hi Dan. The motor seemed to working fine. The switch seemed like it wasn't making a good contact
A.o. Smith gpsh 50 103 tries to light after third attempt shuts down.power down blow air into burner area after cleaning igniter assembly will light usual on first try sometimes second time
The flame arrester are dirty. you can remove burner assembly and blow air back down flame arrester. You will need high temp sealant to seal burner assembly back to prevent flames from coming out the mating surfaces.Raise the heater off the floor. Probably best to change unit. keep floor clean around unit.
Apr 12, 2018 | Smith Computers & Internet
Garage door opener
Check photo eyes. Shut off power to units and try again
Aug 21, 2016 | Building Materials
Just got it. Plugged in and connected wires to 12v battery. Held light/power button 5 secs. Wont start
First, just press and release the power button, you don't have to hold it in.
second, is your battery fully charged?
third, red wire to positive terminal, black wire to negative.
These are obvious things to check, but sometimes the simplest answer is the solution.
Did you install the fuse holder included with the unit? If so dI'd you put in the 3 amp fuse?
If none of these things work, call lowrance. I work in retail and have experienced taking brand new units out of the box and upon hooking them to power discover they were dead. Defective straight from the factory.
Good luck.
Mar 15, 2015 | Lowrance Mark 5x Pro
Why is it not blowing air
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
May 14, 2014 | Haier Commercial Cool 12,000 BTU...
2002 s-10...radio lights, clock and progaming shows up but nothing when i turn volume up
If you mean no sound, could be speaker wires are dead, output to the speakers on the head unit could be dead, if your system is fully amplified, that wire could have come undone.
First question: Is it stock radio?
Second question: no aftermarket items added to the system?
Third question: you mean no sound?
If the answer to all these are yes, test your cigarette lighter to see if it works. If it does, it's most likely the head unit or the stock amp. If it doesn't work, check the ACC fuse, sometimes there is a radio one too. Your head unit has three "power wires" one is constant (Unit turning on, time, etc. The second is the "switch" wire. The third is the ground. I am wagering the switch wire has a separate fuse. Hope this helps!
Apr 09, 2014 | 2002 Chevrolet S-10
No power or picture
hi there! John
Sometimes it is the cable, has to make sure is well pressed, second, cauld be a bad TV power assemble inside. RMS, required. third, some models has two power buttons one is below or side unit, and the other is on the remote , or front /side panel of the TV.
Oct 01, 2013 | Vizio M261VP 26-Inch 1080p LED LCD HDTV...
My steering wheel will hardly turn, what do you think the problem could be?
Hello staffordpain, without knowing what you may have already tried the first thing I would do is check the power steering fluid level. If you find that the fluid is below where it should be, be very careful NOT to overfill it. Your owner's manual will usually tell you if you need dot-3, or dot-4 power steering fluid.
Secondly, make sure that your belt is not worn out, make sure that the belt has good enough contact with the pully on the power steering pump to keep it moving, without slipping.
Thirdly, if you find your fluid is low, see if you have any leaks under your vehicle, you may also want to look under the hood. Sometimes, due to crossmembers under a vehicle the fluid may not make it to the ground.
If non of the foregoing applies, you may want to stop at an auto shop and have the power steering unit checked.
Good luck my friend!
Jan 16, 2011 | 2002 Kia Sportage
Mondeo 2.0 tddi 2001, sometimes when accelerating in second and third there is very quick drop or kick in power or revs, why or what is causing this ?
try cleaning the EGR unit situated near the turbo check the vacuum hoses for leaks.clean out the MAF sensor and connecters situated on the outlet pipe from the air filter box.
Jul 11, 2009 | 2001 Ford Focus
My HP laptop is not booting all of a sudden. Today morning i performed a forceful shutdown of my laptop after which it has stopped booting. On pressing the power on button, all the blue LED glows but the...
Try tapping on F11 after you turn the laptop on, and see if it will go into the recovery mode. If it does, you are in luck, and can choose how you want to do the recovery.
If it does not, you can order a set of recovery disks from HP for about $15us which includes shipping costs. Or, you can load any retail version operating system, and download/install device drivers from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839164&taskId=135&prodTypeId=321957&prodSeriesId=1839143&lang=en&cc=us&submit=Go%20»
Good luck, and please rate my response.
Thank you
Mar 15, 2009 | HP Compaq nx6310 Notebook
Kitchen Ranges Logo
355 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
