Question about LG DLE2301W 27" Electric Dryer with 7.3 cu. ft. Capacity 9 Drying P
Where do the green and white wires (located at the power source) go? What are these wire? Negative, ground, what? Also, where does the connector at the control panel having grey and black wires go?
I tried to change the rollers. Later, when I tried to assemble the dryer back, I couldn't figure out where to attach green and white wires. Also, there is one connector at the control panel with grey and black wires, what does it attach to?
  • LG Master
  • 2,374 Answers
Post some photos of your issues.
Posted on Apr 18, 2015
5 Suggested Answers
  • 21 Answers
SOURCE: power cord
Download the user manual. http://www.retrevo.com/support/LG-DLE5977-Dryers-manual/id/438ag222/t/2/
Posted on Feb 12, 2009
SolutionGuy
  • 331 Answers
SOURCE: Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
Posted on May 23, 2009
heatman101
  • 43501 Answers
SOURCE: I just got an LG
If you have a red wire then the dryer is a 240v dryer and needs a 240v 30 amp circuit...
Here is the manual for your dryer and it shows the hook up you need on page 17...or part 5 of the manual...
Click here
heatman101
Posted on Aug 05, 2011
ashcreekllc
  • 794 Answers
SOURCE: Need to replace wiring harness on LG dryer DLE7177RM model. How can I connect the wires that extend inside behind drum?
Dryers are very easy to repair.
Video on how an electric dryer works: http://youtu.be/2xUKBtLkaeo
Video on how a gas dryer works: http://youtu.be/mcipN8bvpa0
Best regards ~
Posted on Mar 16, 2014
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Trying to hook a tachometer to a 93 gmc seirra 1500 350 were does the green wire go?
The "Green" wire from the tachometer should be attached to the negative side of the ignition coil only, and usually (but not always) it is a black wire with a white stripe or it is a solid white wire that will come off from the negative side of the ignition coil and often has a tab on the wire that says "Test" or "Tach" and the wire ends with an open black connector that is used for connecting a diagnostic device or tachometer for diagnostic purposes, and this is the wire that the green wire from the after-market tachometer should attach to. The "Red" wire should be attached to an "ignition" source connection on the fuse panel and have battery power when the key is in the "Run" position only, the "Yellow" or "White" wire should be connected to the "LPS" source on the fuse panel, and the "Black" wire should be connected to a good ground source and if the tachometer is not properly grounded then you will get a primary voltage shock from the ignition coil every time that you touch something metal inside of the vehicle. Let me know if you require any further assistance.
Oct 19, 2010 | GMC C1500 Cars & Trucks
Car audio wiring diagram
Here is the color code. Is that what you need, or do you actually need the wiring diagram?
2005 Chevrolet Monte Carlo Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Yellow
Oct 15, 2010 | 2005 Chevrolet Monte Carlo
Need radio wiring diagram
Here is color code--will that do for you?
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Right Rear Speaker Negative Wire (-): Light Blue
Sep 26, 2010 | 2006 GMC Sierra 2500HD 2WD
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
Jul 26, 2009 | 1987 Lincoln Mark VII
I want to install a stereo in a 2001 grand am se but the wires were cut.
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
May 30, 2009 | 2001 Pontiac Grand Am SE
Connecting new fan/motor assy
a capacitor is typically inline with your power source and stores a large amount of power to supply bursts of power when heavy draws occur. it sits between the source and the motor so you should have the (source - capcitor - motor) hot wires all conecting at the same place. The other wire on the capacitor should be the ground (if they have +/- markings use the negative as the ground).
Nov 14, 2008 | Amana 30 in. ACC3660AS Gas Cooktop
LG DLE2301W 27" Electric Dryer with 7.3 cu. ft. Capacity 9 Drying P Logo
53 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
