Question about Hinge Saws
Tension hinge for a Cii band saw model number WA -14M
  • 10865 Answers
SOURCE: What size a step pulley required for the motor ?
rpm_chart.jpg?t=1236890602
here is the chart you need to answer your question. please mark this as a fixya! thanks
Posted on Mar 12, 2009
  • 83 Answers
SOURCE: Need a manual for a Skil Metal Band Saw
Here is a link for skill parts and manuals.
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Posted on Mar 30, 2009
efs_perpends
  • 1996 Answers
SOURCE: I need a manual for the Delta band saw model number 28-207
Go to this link, Right click on the underlined PDF below the Publication Preview, and you'll be able to save target as a pdf file onto your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 05, 2009
agent91
  • 2100 Answers
SOURCE: Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Posted on Apr 27, 2010
agent91
  • 2100 Answers
SOURCE: I need an sanding belt 1/2 inch by 80 inches for a
You might have better luck at your local Ace hardware. they can get the belts, also, there are belt makers on line that make any size belt you want, and grit, any type, I can't remember the name, but I'm sure it come up under a sanding belt search, Sometimes they have a minimum order, but if you can't get one from anybody else, check them out. I think it was Sandpaper America.
Posted on Aug 13, 2010
How do I adjust the tension on the saw blade
there is a slide adjustment on the top roller
It is used when replacing broken bands or bands of different teeth numbers
undo the lock nut and screw the adjustment knob until the band "twangs " when flicked
do the nut up tight
Feb 15, 2016 | Ryobi Owner's Manual Model Bs901 Bs902...
I need a repair manual for a trade master 9" bandsaw model Pr13102
Is it the right blade?
Who makes Trademaster tools? - Canadian Woodworking and Home ...
https://forum.canadianwoodworking.com/showthread.php?...Trademaste...
Feb 15, 2010 - 13 posts - ‎12 authors
Can you get parts for them? Is $250. a fair ... Home Hardware has been sellingTrademaster for a couple of years. ... It's identical to many other models. ... I still own my 14" trademaster bandsaw. ... 02-16-2010, 03:38 PM #9.
Woodworking - Band Saw Setup and Tuneup - YouTube
? 13:04
https://www.youtube.com/watch?v=ZnqsEszw6xM
Apr 12, 2011 - Uploaded by WoodWorkWeb
Setting up a band saw correctly is an important set in order to get ... Woodworking - How to Adjust for Band Saw Blade Drift -Workshop ...
Jan 21, 2016 | Blade Saws
Tighting blade for duracraft bench bandsaw model bbs412 variable speed
You mean tensioning the blade? I suggest you to read the blogs on bandsawblog.com. They have blogs about band saw blade tensioning, tracking and tuning up band saw.
Sep 28, 2014 | Saws
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
I have a 10" band saw model 124.214000 how much tension do i need put on blade or the proper way to adjust the tension.
I've been having hard times also putting right tension on my Haltbar blade . Try reading this blog : http://bandsawblog.com/blade-tension/
Hope that helps.
Feb 08, 2013 | Cars & Trucks
I have a craftsman band saw model 137224120 and need a shaft for the lower wheel and tried to order one and this part has been discontinued, any idea where to find a replacement one
I have the same saw and my shaft was also worn out. I was frustrated that there is no replacement part. Here's what I did (and it's worked great - so far): I put JB weld (metal epoxy) on the worn section of shaft and let it cure overnight. I then chucked the shaft in my drill press and ground the JB weld back to the correct diameter by holding a metal file against it. I polished it smooth with some 800 grit wet/dry sandpaper. Replaced it in the saw and it works with no wobble.
Feb 27, 2012 | Craftsman Saws
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the...
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Nov 14, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
Mar 08, 2009 | Saws
Saws Logo
235 people viewed this question
Top Hinge Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hinge Saw Expert? Answer questions, earn points and help others
