Question about Timex Watches
Have a 4 button Timex Expedition (Indiglow - 100 meters). The lower right button no longer works so I can't change settings. Recommendations?
  • 682 Answers
Take the back off and examine if the pin from the button is still able to depress the switch or if it's clogged up with debris.you should be able to depress the switch with a sewing needle to adjust from inside the watch.be careful not to lose the screws off the back.good luck.
Posted on Apr 12, 2015
  • Craig Wilcox Apr 13, 2015
    Thanks, John. Your tip got me up and running. Appreciate your help.
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Posted on May 15, 2008
  • 3 Answers
SOURCE: Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Posted on Aug 18, 2008
  • 8 Answers
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
Posted on May 27, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Posted on Jun 17, 2009
Replace battery on timex indiglow but just drains battery
It sounds like there is a short somewhere, or the Indiglo function is permanently on.
I suggest you look inside the case and check the movement and how the battery was installed and see if anything looks wrong.
If you can find nothing amiss I suggest you take it to a jewellers or similar that does battery replacements and let them work it out.
Hope this helps.
Aug 30, 2017 | Timex Watches
I 'm facing difficulty in adjusting the alarm with
from the time mode of the digital, just press the mode button until it reaches the alarm mode or sometimes it shows "12:00" then press and hold the lower left button to set, the digits blinks then the upper right button is to adjust, the lowerleft button is to choose what are you going to change. press the set button when your done. i hope i had been helped you.
Aug 10, 2011 | Timex Expedition 84601 Wristwatch
I 'm facing difficulty in adjusting the alarm with the Timex Expedition Outdoor Casual Combo 84601 Wrist Watch
from the time mode, press the mode button/lower left button until it reaches the alarm, then press and hold the lower right button which is the "set" button, until the seconds blinks, use again the mode button to choose what are you going to change, (note: the digits that are blinking is changeable using the upper right button) if your done, just press the "set" button/lower right button once.
I 'm facing difficulty in adjusting the day, date, time, alarm for my "Timex Expedition Combo Mens Watch T84601". Please help.
on the lower right button, you will see the set button, press and hold it until the digit blinks, now you can adjust it. use "mode"(lower left button) for choosing what part of the digits are you going to change. use the upper right button for adjusting the digits that are flashing. when your done, press again the "set" button to finish. i hope this will help you.
Aug 09, 2011 | Timex Expedition 84601 Wristwatch
I need an owners instruction sheet to learn how to set dATE & TIME.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 06, 2011 | Timex Expedition Perpetual Calendar...
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
How to set the time on timex 1440
Hi r3girls1,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Sep 13, 2009 | Timex 1440 Nylon watch
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    Mar 30, 2008 | Timex 1440 Nylon watch
    Setting tha alarm
    Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
    Dec 21, 2007 | Timex Expedition 40141 Wristwatch
    Watches Logo
    49 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Mark Schmit
    Mark Schmit
    Carol
    Level 1 Expert
    Are you a Timex Watch Expert? Answer questions, earn points and help others
