Question about Sta Rite Maxi Therm 400k Btu Propane Heater
Heater wont exceed 95 degrees - Sta Rite Maxi Therm 400k Btu Propane Heater
  • Sta Rite Master
  • 1,631 Answers
Possible bad temp sensor / thermistor?
Posted on Apr 15, 2015
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
H400ed2 heater digital displays not working all the time only increase in incriments of 10 or15 degrees
i the heater is functioning other than that, i would not replace anything. from the sounds of it, the actual increase/decrease button may be stuck. in any case, the heater was set with a maximum value at the factory and will not exceed 104 degrees in any case
Jun 16, 2014 | Hayward H Series Pool & Spa Heater 400k...
104 degree limit
there is a white button on the back of the heater control board you can hold it down and raise the temp that way, but yes it is not healthy to have the water that hot it is dangerous to your health
Feb 26, 2014 | Pentair Mastertemp Heater
What are the torque specs on a 2000 Nissan maxima head
NOTE
If possible, replacement of the head bolts is suggested.
  1. If replacement of the head bolts is not possible, perform the following bolt measurement:
    1. Measure the diameter of the head bolt 0.43 in. (11mm) from the bottom of the bolt.
    2. Measure the diameter of the head bolt 1.89 in. (48mm) from the bottom of the bolt.
    3. Whenever the size difference between the 2 measurements exceeds 0.0043 in. (0.11mm) the head bolts must be replaced.
  2. Install the cylinder head bolts and torque in sequence as follows:
    1. Step 1: 72 ft. lbs. (98 Nm).
    2. Step 2: Completely loosen all bolts.
    3. Step 3: 25-33 ft. lbs. (34-44 Nm).
    4. Step 4: plus 90-95 degrees clockwise.
    5. Step 5: plus 90-95 degrees clockwise.
Aug 30, 2012 | Cars & Trucks
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
What is the correct engine temperature
95 in celsius is 202 degrees in fahrenheit. the cooling fans kick on at 190 degrees. 202 is hot but if its been a long time the thermostat been change . change it.wont hurt it.
Apr 11, 2009 | 1994 Jeep Grand Cherokee
Sta Rite Maxi Therm 400k Btu Propane Heater  Logo
124 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
