Question about Samsung RF4287HARS 28 Cu. Ft. French Door Refrigerator in Real Stainle
Samsung RF4287HARS E4 error on display: SOLVED. This is a fix that I had to do after the service technician said it was un-repairable. Error E4 on display.
The upper shelf in the sliding freezer drawer has too much food toward the right side and rips the thermistor sensor off the roof of the freezer cabinet.
  • John Maurais Apr 12, 2015
    Here are the pics
    I soldered the wires to extend them and finished off where I trimmed the cabinet with a hot glue gun. Be sure not to cover the slots in the cover as the sensor need to be exposed to the freezers ambient temperature. If you aren't good at soldering and heat shrinking, have some do it that is. The wires are rather short and you only have one chance to extend them. Also, be sure to unplug the unit. To remove the drawers and front, download the manual from the Samsung website.
  • Samsung Master
  • 5,323 Answers
Do u mean the thermistor? if so it can be reinstalled in the same general area and will still work
Posted on Apr 21, 2015
Power module replaced on my Thermador T241F70NSP/03 built-in-freezer which fixed inoperative display. Now I get a click sound but the compressor is not starting. How do you check compressor?
You bought a Fancy fridge, now pay a Fancy technician to fix it...
Trying to own Thermador appliances on a budget is not possible nor is it intelligent.
Sep 03, 2016 | Thermador Freezers
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
Replace noisy freezer fan on samsung rf4287hars
fan is in the freezer behind back wall, and it needs to be removed to access the fan motor .
Aug 29, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
My Sub-Zero 601F Freezer displayed -20 and no matter what I did, it would go back to -20. It turned out that the relay board needed to be replaced because the motor kept on running and never shut off. ...
repairs should be performed by a qualified service technician. possible open thermistor in the refrigerator/freezer. the freezer/ thermistor connection may be corroded. check if the evaporator fan motor is running. yes the service technician should check the operation of the refrigerator/freezer.
Apr 27, 2017 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Portable ice maker not working as good as it did
Hi
Kindly refer to the Haier service manual which will help you for sure.
Thanks
Rylee
Jan 30, 2009 | Haier Freezers
Samsung RF4287HARS 28 Cu. Ft. French Door Refrigerator in Real Stainle Logo
59 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
