Question about Philips BDP2185 F7 Blu ray Player
I HAVE NO SOUND COMING OUT OF MY BLUE RAY PLAYER. have checked all connections. Vidoe does play
    Master:
  • Philips Master
  • 487 Answers
Suggest that you Contact Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Posted on May 05, 2015
3 Suggested Answers
  • 255 Answers
SOURCE: I have recently purchased a Philips Blue ray
This has happened before when DVD players first came out. It REALLY happened when CD players first came out. The machines were "picky" with the disks they wanted to play. As they get better and better at building these machines, this problem will go away. . Try this: Put some Armorall or SonOfAGun on it. wipe it clean with a scratch-free cloth RADIALLY - that is, don't go around in a circle. Wipe from the inside to the outer perimeter and beyond. Get it nice and clean. I be a dollar and a donut that it will work. It is a great way to protect your disks too!
Posted on Nov 25, 2009
Testimonial: "Thank you for your advice. Your right it has solved the problem. Thank you."
SOURCE: player will not play blue ray discs
I'm having the same issues.....Anybody?
Posted on Sep 29, 2010
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
Can i connect a blue ray dyd player to a tru tech tv
If your TV has an audio/vidoe input, you can. If has HDMI, better
Jul 11, 2015 | Televison & Video
What connection do I use to connect a sony blue ray disc to on a Yamaha htr 6030 reciever to play music cd's
You said "...on reciever cd out in the audio box..." but it should the reciever IN that you connect to. Also is the BlueRay player capable of playing CD's ? When you press play on the sony remote, do the seconds start counting on the screen ? (ie: is it playing, but no sound is coming out?)
Dec 02, 2014 | Yamaha Audio Players & Recorders
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
Philips BDP2185 F7 Blu ray Player Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
