Have tried to reset. Did not work. Have tried several outlets. Did not work. How do I chcek the battery.
  • 682 Answers
It would help knowing what operating system is I.e. Windows 7 or 8.can you get into safe mode by repeatedly tapping f8 this should give you drop down menu for last known good configuration.choose this to see if the laptop returns you to a desktop.the battery can be checked by leaving the power supply in until you get to the open screen desktop then remove power supply and check the icon for battery bottom right.if you hover the cursor over the icon it will give battery life in percentage.batteries eventually fail mainly because people do not charge them properly.you need to run it flat occasionally and do a full recharge.once it reaches 100% take the power supply off and run it down to 20% and charge back to 80 % half a dozen times in between full charges?also in control panel there is an icon for battery whereby you can force the battery to discharge so you can re educate the full charge memory,this usually increases the stamina of a failing battery.
Posted on Apr 12, 2015
Where is the reset button?
Baattery is probably dead if it has been plugged in all the ime replace it.
Jun 16, 2014 | Gateway LT2021u 10.1-Inch Red Netbook - 3...
Sylvania sa 140 digital timer
Sylvania timers often come with long warranty. Call 888-548-4484/ hardwareinnovations.com
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Usually if batteries are changed, you want to reset timer. Press reset button, for 5 seconds and then reprogram. If functionality is not restored after reset, then timer has gone bad.
Check outlet for power, makes sure bulb is working, turn light on, try timer on different outlet and with different lamp.
Gene
h
Aug 08, 2013 | Hardware & Accessories
Wont start
Are you sure your USB charger is working properly? Have you tried replacing the battery? You might try this trick: Make sure that your Notebook is plugged into the charger and that it is plugged into the power outlet, press the power button and hold it down for 20 seconds, then release the button and wait about one minute, now press the power button again and hold it down for 20 seconds again. Hopefully, this will reset your system.
Jun 27, 2012 | ASUS Eee PC 1000H Laptop
99 expedition windows won't work,wipers,ac,heater,dome light,radio... tried several GEM modules took it to dealer to set the codes and was told it would not except the codes , HELP!!!!
Your post is ambiguous, I am not sure if you are saying that is a whole list of things that don't work, if that is the case I think you have a lost the main feed to part of your fusebox.Have you done any basic voltage checks?
Sorry I can't be of more help.
Nov 01, 2011 | 1999 Ford Expedition
Had to change battery. Since I did this the day will scroll several times and will not let me set the day, nor the time, nor the mode. Is my unit toast ?? As it was working till I changed the battery.
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Jun 19, 2011 | Intermatic HB88RC - 7-Day Programmable...
Battery doesn't appear to be charging.
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
Mar 19, 2011 | Dell Studio 17 Laptop
Forerunner 205 wont turn on
"To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
If the unit is no longer displaying maps or lap data in the PC downloaded history ....perform a reset (as above) AFTER deleting all the Garmin HISTORY. This is done on the unit by navigating through HISTORY to "DELETE ALL" ---> now perform a soft reset.
Dec 10, 2007 | Garmin Forerunner 205 GPS Receiver
New batteries will not charge
a technician ' s adjustable bench power supply - set for 9 volts at 1 amp - for a minute or so , will initialize most new lithium batteries ( a charger update may also be available ) ;
Sep 18, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
