I am looking for an amplified TV antenna to receive several stations within line of sight about 20 miles away.
My problem id ht Emire State Building is 2 miles away. and my elevation is about 200 feet. The signal overloads anything but a rabbit ears antenna. Is there an amplifier made that can still amplify and handle this overload and still work to receive without distortion.
  • 2,402 Answers
I have an ordinary antenna for digital TV and use an ordinary amplifier that one end fastens up within six feet of the top of antenna and the other end plugs into an electrical receptacle in my house and both ends are right on my antenna wire that hooks to my tv. I live 80 miles from Detroit Michigan and across Lake Erie from Cleveland Ohio and I get 50 channels on my tv. all the time
Posted on Apr 12, 2015
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
Only 2 FM stations working. I have an Insignia Stereo receiver. At first, we could get all of the FM stations, then all of a sudden we can only get two. The antenna has not been moved from where it or
If you have an external antenna, check you antenna connections.
Weather can change your reception. Are the stations you can hear local? within 30 miles? Or is there an amplifier on your antenna system? It may have quit functioning. if you have cable TV you might want to hook up your stereo to that system, you will need a 75 to 300ohm adapter that you can pick up from an electronics store or online.
(coax to twin lead)
Sep 27, 2014 | Audio Players & Recorders
My out door TV antenna stopped receiving 1 of 8 channels, this station is 20 miles away, the station said they weren't having any problems transmitting, do I need to replace the ohms device?
Is the antenna digital? If not its analog. Most stations are going to digital HD and dropping analog. The other 7 are still broadcasting analog. Ask station if they are still broadcasting analog if antenna is digital. If no, do a rescan of stations in menu of tv. Let me know.
Feb 19, 2013 | Electronics - Others
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
26" ILO digital T.V . won't pick up digital signals w/digital antanae.\r\nusing air in setup
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Sep 11, 2010 | iLO 2600 Television
What antenna do you recommend wit the RCA 20F510TD
This tv has an analog tuner so you will need a digital-to-analog tuner set-top box (assuming you live in an area where most stations have been converted to digital TV broadcast). Whichever tuner you use, the recommended antenna will depend on where you live and how many tall objects are between you and the transmitters. Go to antennaweb.org or tvfool.com and type in your address. Antennaweb assumes an external antenna but is still very conservative in the channels it will identify as watchable in your area. Tvfool.com lists the channels by direction and the antenna type (by color) you will need to receive them. The color rating is based on how far the stations signal travels to reach your location. An amplifier can help you receive stations that are marginal to your location. (Digital signals are sufficient for the TV to tune them in or you get "no signal" messages.)
I hope this helps.
(I'm in a rural area with an external antenna with a signal splitter/amplifier. Antennaweb suggests I will only get the stations ~10 miles away. In fact I get the stations from there as well as the ones ~30 miles away.)
Sep 11, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Nhens convertor box www.dsconter.com
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Aug 29, 2008 | Philips Magnavox 20MT133S 20" TV
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
