Question about Garden
I get nothing when I turn the key, no lights any ideas what it could be?
  • Kathy Fuller
    Kathy Fuller Apr 22, 2015
    Thank you it wasn't the batteries but the ground wire that had broke off. Although we now have dash lights we cannot get the tractor to turn over unleas we ground out the solenoid.
    Sergeant:
  • 462 Answers
Boost your battery dear
Posted on Apr 23, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Well, Kathy, if the tractor has been sitting for a few months, like over the winter, chances are the battery has lost a bit of its charge. A general rule of thumb is a dormant battery will lose approximately 1/2 volt each month its sitting in a non-running vehicle or without a "float" charger.
However, the first thing I'd do would be to remove the battery terminals and thoroughly clean inside the cable ends as well as the actual battery posts themselves. There seems to be a tendency for those old terminals to corrode up a bit and inhibit the current flow.
Be very careful NOT TO GROUND out your wrench on the frame of the tractor or the gas tank as you are removing or re-installing the battery because you could cause a direct short to ground with your wrench and make you really jump out of your skin !!!! Follow the cables and find the one that grounds to the frame and remove that one first then the other one and that will minimize the chance of grounding out the wrench. Then reinstall that one last.
If after cleaning the terminals AND the cable ends there is still a problem, consider having someone charge your battery fully and try it again. You should at least get something to happen with a fully charged battery and clean terminals though. If not, post back the results and let us know what did and what did not happen and we can walk you through the next phase.
Posted on Apr 12, 2015
  • Kathy Fuller
    Oops I commenter in the wrong spot. Well I now have dash lights. Looking AR the batteries I found the ground wire broken off. Now I've got new batteries, cables, starter and soleniod and the only way to get it to turn over is to cross the ground on the soleniod and it still won't start.....help.....Please
Turn the key and nothing....
the small wire at the starter may be corroded and not offering a good contact. With a helper turning the key check for power at the small wire at the starter. if there is power with the key in the crank position and the connection looks clean that the starter is likely bad.
Jan 04, 2016 | 2005 Ford Freestar
Range rover P38 1995 2.5 Diesel auto .would not turn over all lights and Windows working new battery ok yesterday
when you lock it up does the alarm activate you say this problem only started after changing battery sounds like its the mobiliser lock and open car from inside with key in ignition hope this helps
Mar 14, 2015 | 1995 Land Rover Range Rover
Will not turn over
If the lights work but no crank, it could be the security system or the neutral safety switch among other things.
Is the security light on or flashing ? Do the warning lights come on when you turn the key on ? Did you try cranking it in neutral ?
Jun 02, 2013 | 2001 Oldsmobile Alero
Hyundai accent 2002 turn key nothing happens?
If you turn your key and get no response its scary I am sure. I need to know a few things to get a better idea on what is happening. 1) Are your connections loose on your battery terminals? 2) Did it have any warning or did it just give zero responce one day?
Feb 12, 2013 | 2002 Hyundai Accent
Vw jetta glx vr6 key turns in ignition,but nothing happens
The first thing I would check is the starter motor fuse and relay, but the lights staying on is weird. Perhaps the ignition key switch is defective. That could be caused by many things including wear and tear / moisture / insects, especially if the car is old and you are living in a warm and humid climate.
Sep 01, 2012 | 2004 Volkswagen Jetta
Battery is good, no lights, no nothing when key is
May be ignition switch and/or neutral safety switch (IF equipped with one). Brake light switch and neutral switch may be working in union. Sww if you can see it under the wheel on the column and tell if you can adjust it first before replacing.
Mar 09, 2010 | 1991 Ford F150
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
