Question about GPX Kc232S Under-Cabinet RadioGPXKC232S
Lost power, when power went on no power to radio. outlet has power clock on same outlet works fine
Clock on radio works but no power to radio
  • EDWARD ABPLANALP Apr 14, 2015
    clock works but radio will not play. there is power to the radio
    Top Expert:
  • GPX Master
  • 44,428 Answers
Many radios need turned back on after power failure
Posted on Apr 14, 2015
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
What will cause my radio,clock and power outlet not to work?
Let me ask a few questions: The items mentioned, radio, clock and power outlet...are these the only items not working? does the instrument panel light? Also , does the cigar lighter work? Lastly check fuse # 7(40A) in the battery junction box
Jul 03, 2014 | 2003 Ford Focus
10 September 2011 I have a Denon clock radio in the kitchen, but it's not working. In fact, it hasn't worked in a long time. Help me. Serial # 71101100576
Hello there,
First you need to check if it is receiving power, try to connect the cord to another device to see if it will power it up. If it does, then it means the power cable is okay and does not need replacement, but if it does not power it up, then it means the power cord is bad and need to be replaced.
If the power cord works perfectly fine, check if the outlet is supplying current by plugging some other device to it to test if it is working.
If the power outlet is okay, then it means the problem is from the power board inside the unit of the denon clock radio. Have the power board checked for bad capacitors. If none found, replace the power board.
This time it should work.
Would be glad to know if this information was helpful to you. All the best Elect_Comp
Sep 10, 2011 | Vacuums
When I plug my Bose clock radio into one outlet, I get nothing but static. When I plug it into a nearby outlet (with out really moving the cord), I get perfect reception. The problem is the outlet where...
The Wave Radio uses the AC power cord as an antenna. Perhaps the two outlets are wired differently regarding ground and hot.
An interesting article...
http://www.gcaudio.com/resources/howtos/acpolarity.html
As the man says in the article thecircuit tester like this...
http://www.idealindustries.com/products/test_measurement/electrical_testers/circuit_tester_e-z_check.jsp
... can be found at many Dollar Stores for cheap.
Mar 06, 2011 | Bose Wave Radio
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Jan 30, 2009 | Emerson Smartset Clock Radio
12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | RCA RP5420 Clock Radio
Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 30, 2007 | RCA RP3721 Clock Radio
GPX Kc232S Under-Cabinet RadioGPXKC232S Logo
79 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
