Question about Toshiba REGZA 47HL167 TV
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
The menu still displays just nothing from any video inputs i dont think its the inverter is there a factory default i can reset it to thru the service menu if so whats the code i need to input?
    Master:
  • 426 Answers
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Posted on Apr 12, 2015
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Jan 05, 2014 | Toshiba REGZA 47HL167 TV
I have a toshiba 43ax60 has sound no picture and the power light stays on when powered
you need to explore menue for tv options and select the proper input as well as other options.
Sep 17, 2012 | Toshiba 43AX60 43" Rear Projection...
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
NO SOUND GOOD PICTURE TV IS ONLY 5 MONTHS OLD
Unplug,replug the tv back about an hour later.Go into the tv menu,go to SOUND,go down to reset it to back to factory setting.The sound now should return,not,than ur tv the Tuner board have problems,call for warrenty serviced.
Jun 28, 2010 | Toshiba REGZA 47HL167 TV
No picture no sound
check the input selection on the tv make sure it is set to the correct one that you have connected.
also give it a few second at each input to pick up signal and display.
if you cycle thru them all and there is still no picture check the devise you have connected to it and try to connect another device to a different input.
if you can get nothing to work on any correctly connected input , i would look into the retailers return policy
Dec 31, 2009 | Televison & Video
47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Dec 15, 2009 | Toshiba REGZA 47HL167 TV
47" Toshiba Regza 47HL167 - No picture but with sound
My guess would be to suspect the inverter. but from what i can tell that model had two possile inverter types used during production.
toshiba P/N 75008432 Rev C3
AND
75008433 V470H1-L
Oct 06, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a 32 " 1080 PI LCD Regza. Have audio but no picture. Menu items come up on screen, but no input from Sat. Box, Xbox etc..
check your power supply. and check your
invert board back lamp driver if you have a
miltmenter check your vote at the invert board.
if you do have the rigth volt yiu have a bad invert board.
Aug 10, 2009 | Toshiba REGZA 47HL167 TV
No picture on my television
Found this on the www.toshiba.com website. Q. I have sound and no picture with the TV powered on?
Models: 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL67, 42HL167, 47HL167,
52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00111
Using the buttons on the TV itself (not the remote control), press the “MENU” button to see if the TV’s MENU appears on
the screen. If the MENU does appear on the screen, verify that all of your video connections are secure on the TV and on
the connected device. Double check that you are connected in the appropriate jacks, check the other inputs of the TV to
see if the video appears on any other input. If you still do not see any video but can access the menu, try to reset the TV
to the factory defaults.
1. To reset all settings to default values:
i. Press the “MENU” button on your remote to open the menu.
ii. From the SETUP menu, highlight INSTALLATION and press “ENTER”. A new set of Installation
menu icons will appear.
iii. Open the SYSTEM STATUS menu, highlight SYSTEM INFORMATION and press “ENTER”.
iv. Press the LEFT or RIGHT arrow to scroll through the menu bar to select FACTORY DEFAULTS.
v. Enter your PIN code (or 0000 if no PIN code has been set).
vi. Highlight YES and press “ENTER”. The TV will turn off automatically after a few seconds. After the
TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
vii. If the MENU does not appear on the screen, try resetting the TV by unplugging the power cord for at
least 3 minutes.
viii. If neither of the above steps resolved your problem, you can get assistance with this problem by
contacting our customer solutions department at 1-800-361-3811 Monday through Friday 8am -7pm
CST I hope this helps you with your problem.
Nov 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
May 30, 2008 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 47HL167 TV Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
